Question about Gaggia Titanium Espresso Machine
Machine makes coffee, but no water or steam come out of the steam pipe. The steam compressor is making its usual sound, but only a small dribble comes out. I have cleaned everything, including the steam pipe
  • ctors Jul 28, 2010
    The solution was not really a solution, but it was helpful. It still points to me having to take it somewhere to get it fixed. But many thanks anyway!
    Brigadier General:
  • 3,917 Answers
Hi
Most probably you have a tube that is leaking inside. Contact the company that you got it from to get it checked or diagnosed.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
We got a gagia expresso color machine recently. We used it for a week and now the machine is not is not dispensing expresso. The machine makes sound but no expresso comes out. The tank has enough water....
Your are propably need to prime the machine. This mean that air blocked in the machine and need to get out and fill all pipe system with water.
To do this you need to warm up the machine and turn the hot water knob so you will get one cup of hot water from the steam wand. After that try to get some water from the coffee head without any coffee in the filter handle. Now the machine is ready for coffee again. You will need to prime the machine very often so try to remember the procedure. This will happen again usually after you use the steam process and this normal for your machine.
http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime
May 01, 2011 | Gaggia 102534 Espresso-Color...
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Gets no steam
If you can make coffee and the coffee is hot that means the machine works fine and the only problem you have the tube nozzle clogged. So first switch of the machine a turn the knob to off position. Remove the steam nozzle cover and with the use of a needle or steel thin wire insert it to steam pipe all the way in so to make at least a small opening. Try again to work the machine and if you have atleast some steam continue use the steam so any dirt will spit out. The dirt might be dry milk or evn some big parts of scale which have been unstuck from machine during descaling and they have not desolve so to come out from the pipe. So the next time you will make descaling try to leave the machine with descale solution more time inside the machine before rensing.
Good luck
Please remeber to vote for this answer
Mar 13, 2010 | Saeco Incanto Classic Espresso Machine
How strong should the output for the cappucino/ latte steamer? Mine just sort of dribbles the steamed milk. Thanks
When steaming the milk/cream make sure to hold the rubber nozzle to the very bottom of the cup and also make sure you are leaving enough water to produce the steam after brewing a cup of espresso. Also you'll want to check the breather tube that sticks up from the nozzle and make sure it is free of buildup.When the steamer is operating correctly it should produce a loud growling sound.
Nov 06, 2009 | Nespresso D290 Espresso Machine
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Maxkon SK 201A Coffee machine only has one rubber pipe
hi - had same prob= found out modern maxcon machine has only one tube in water tank- other is internal. turn steam knob to off position- anti clock - and wait till water / coffee light is green- then water will come out from filter . when wanting the steam- turn the steam knob clockwise - hope this helps - susan
Jun 27, 2009 | Coffee Makers & Espresso Machines
Ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Mar 22, 2009 | Gaggia Syncrony Compact Coffee...
No coffee
Make sure the water pipe not is broken.
If you take out the brewing unit and look at the chassis on the machine, you can see a hole, there should be a little plastic pipe comming from the machine down to the hole. If this is broken then the water will go to the driptray.
/Mirran
Aug 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
43 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
