Question about Bosch WFK 2401
WFK 2401 DOOR does not open anymore
My Bosch WFK 2401 is probably over 5 years old(don't know exactly since I got it from my previous home owner) and stops at the end of the cycle time remaining, 1, at any setting, and does not unlock.
The only way I can unlock it at this point is by turning it to "X" setting, turn the switch off, press both Start and Pre-Wash buttons simultaneously, then turn the switch on. This sets it to "00"(default)mode. I then turn the machine off, turn it back on after 20 minutes, then the lock finally unlocks.
This does not always work either.
The door also has trouble locking, not unless I slam the door shut a couple of times. Obviously there is something wrong with the door mechanism or door computer on/off/unlock/lock chip(?) Is this something I can fix on my own by replacing the door lock part? How do I even open the rubber part?I did find a part for the lock, or is this far more complicated, like the whole processor is gone.
  • 21 Answers
Where is this machine i might be able to help over the phone
262-893-4840
Posted on May 02, 2008
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, the spin cycle on our bosch wfk 2401 suddenly stopped working. The wash and rinse cycle works but when it's time for the spin cycle to begin, the machine hums as though the motor is straining...
If there is motor humming while the spin cycle is ON , please confirm if the motor also heats up-- take caution not to touch live points. Also if you manually push the motor with care so see if the spin starts up then the capacitor (this assists with the starting) can be weak or faulty.
Remove and check with a mains tests and see if the charge retains, if not change. Other wise check if there is friction on the motor or drive.
Jun 14, 2011 | Bosch WFK 2401
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Sep 19, 2007 | Bosch WFK 2401
Washing Machines Logo
335 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
