Have a 4 wire input into my thermostat but the thermostat is a 5 wire unit for heat/ac and the thermostat is an intertherm. Will any thermostat for heat/ac work and is the wiring different. Wires I have are Red, White, Green, and Yellow. The thermostat has O, B, W, Y, G, RC, and RH.
    Guru:
  • 588 Answers
Red wire goes to Rc with a jumper wire to Rh
White wire goes to W
Green wire goes to G
Yellow wire goes to Y
Posted on Jul 28, 2010
    New Friend:
  • 54 Answers
Depends if you have a heat pump or just a straight air condenser with heat strips as your only heat source. If heat pump you would need atleast 5 wires red to r green to g white to w yellow to y and orange to o/b for heat pump. If o and b are sperate you ha e to determine if reversing valve is energized in cool mode or heat(usually cool) so it'd be o. Alot of thermostat have one terminal labeled o/b and you input when energized in programming of tstat. But if just a straight air with heat strips red is r yellow is y g is green w is white and c is common the only reason you would want this hooked up at tstat is if you have a battery powered thermostat this gives the thermostat power so batteries are not necessary other than that don't worry with c you can change batteries. To determine if reversing valbe is energized in heat or cool for heat pumps just try one and put in cool.mode if unit blows heat then swap it
Posted on Oct 29, 2016
I have a Intertherm heating and airconditioner unit and the ac works but when I go to turn on heat I get a humming noise only 2009 or 2010 Mobile home unit
turn power off and put red wire in with white wire at tstat and turn power on. if heat works it's possibly a configuration issue or a tstat issue. keep us posted.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Intertherm Heating & Cooling
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
As I was cutting weeds away from my outdoor ac unit, I accidentaly cut through a small wire that has a red and white inside of it, we wired them back together and still have no ac or heat or air, we just...
first try turning off the power to the furace for 15 sec and tunr it back on (reset the computer) you may have blown a control fuse on the contol board inside the furnace, turn off power and becareful of hazardous voltage conditions
Aug 15, 2009 | Intertherm P3RA-048K Air Conditioner
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Nov 26, 2007 | Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
