The cold water on my Kenmore #110.82673110 washing machine does not work....barely trickles out....the line is not clogged.
  • 145 Answers
The fill valve, where the hose hook to the back, has gotten plugged with sediment. You will need to replace the valve.
Posted on Apr 23, 2008
Silt, sand, something from deep water well has migrated past exterior washer hose screens into washing machine. Older Kenmore HD Series 70 top loading washer. How to fix?
probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
Feb 04, 2018 | Kenmore Washing Machines
Kenmore heavy duty 80 model 110. rinse cycle at cold is down to a trickle, and seems to be lessening. Takes hour plus for a full water load if mixed alright flow for warm and hot
Your cold water line is clogged, kinked or the water valve solenoid is not opening all the way. First check the hose, then the screen on the valve for clogs. If none then replace the water valve assembly.
Dec 15, 2010 | Kenmore Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Washer will barely fill with water for the rinse cycle it can take several hours.
hi..the reason to this problem is the pressure hose,
it might have got clogged.
check this out..
thank you..
kindly rate my response..
Jul 19, 2009 | Kenmore 22422 Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Cold water is trickling in
Brushing,
There's a chance that the screens on your inlet valve have gotten clogged. Turn the water off and remove the hoses from your inlet valve on the washer. Inspect the screens there... if they're clogged that's your fix! Clean them out and you're good.
If the screens are clean, that means that your water valve has gone to appliance parts heaven and should be replaced. Watch this video to learn how to gain access to your machine...
The valve you'll need is part number 285805 and it's a breeze to replace. After you have the cabinet off, you'll see it on the right side of the rear panel.
If you have any further questions or if I can help in any other way, just write back.
Don't forget to rate this solution!
SG
Apr 09, 2009 | Kenmore Washing Machines
The cold water does not run it trickles, hot water runs very fast
If both solenoid coils check the same, you probably have a clogged supply hose. Check that the filter screens inside the hose (if present) and the fill valve inlet are clear of mineral buildup. Try switching the hot and cold supply lines to see if the trouble moves from cold to hot. If the cold still only trickles in, replace the fill valve.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
