Question about Acura Car Audio & Video
Radio code for acura MDx 2001
My audio system was disable due to battery problem and a ''code'' was required to start the system. I am the 2nd owner of the car and I don't have the code.
my car is Acura MDX 2001
  • 73 Answers
You will need to go to the dealer, they have the code that you need.
Posted on Jul 28, 2010
Open thepasanger side jar and on the side you will see the code
Posted on Jul 29, 2010
My acura 2002 MDX does not start nor crank... I see red light is blinking( security system)
you more then likely have an anti theft device, trying putting a flasher on either left or right and try, due all the dash gauges light up when you put the key to the on position? you can try unplugging battery and replugging it, ensure you have the radio code for stock radio before doing so.
Dec 29, 2016 | 2002 Acura MDX
I removed and the radio stopped.pls help me with the code.serial# U2200L3802
posted 6 times. RTM , its all there, read it.!!
2008 opr.guide.(lost it, huh?) Accord. non satellite
Quotes:
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because thereare hundreds of number combinations possible from the five
digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, youshould write the audio system's serial number in this owner's manual.
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries toenter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars'
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
Nov 26, 2013 | 2002 Acura MDX
Acura MDX 2002 Model, the sound system requesting for CODE to function
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Jan 04, 2013 | Cars & Trucks
My radio code 25451 is not unlocking my radio,on acura mdx2002 model
Aug 30, 2012 | 2002 Acura MDX
My radio is locked and need the code i had to recharge the battery 2001 acura mdx
if it's not in the glove compartment,you will need to remove radio and call dealer with the number on top of radio to get code.
TIM.........
Nov 03, 2010 | 2001 Acura MDX
I need radio code for my acura mdx 2001 radio when i removed the baterry terminal for cleaning.
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Aug 09, 2010 | 2001 Acura MDX
2006 acura mdx. battery completely dead now I
Feb 08, 2010 | 2006 Acura MDX
Changed battery of my 2002 acura mdx, need codes for radio nav
You need to get the serial number off the sticker attached to the radio and nav. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Nov 29, 2009 | 2002 Acura MDX
The 'Maintenance Required' light flashes on my
this is just your maintence minder. the reset procedure should be in your owners manual. the vehicle calculates when its due for an oil change and turns the light on but it should be reset every oil change if its on or not. you can can your local acura/honda dealer and they can explain how to reset
Nov 02, 2009 | 2001 Acura MDX
I had my car serviced and now my radio just says code, it is a 01 Acura MDX . I do not know the code do you
Best way to find this is look in side your owners manual. It is security code to protect from theft. If not call a Acura dealer or the shop you had it done at. They should help.
Aug 15, 2009 | 2001 Acura MDX
Open Questions:
Rearview backup camera not working, flashing screen. Not tailgate camera wire problem. Please Click "Want Answer" to get this question answered. Just to start out, I have replaced the entire camera wiring harness so a broken wire there should not be the culprit.I've had the MDX for a 4 years and the camera and Navigation have not worked for years. I recently replaced the Navigation unit hoping it would also fix the camera issue. Now the Nav is working as it should but the camera is still not working, still flashing between black and white with no picture visible. I have been able to bring up the brightness menu through the nav screen to adjust up or down screen brightness but it has no impact when I increase or decrease the brightness. I've read a lot on about every possible forumn. When my MDX is in reverse, my backup camera does not work. I did research and find the most common reason for failure related to severed wires (red wire usually) in the passenger side boot between the tailgate was broken. Mine was broken too and I started with soldering the wires together but that didn't work. I then purchased ($28) a new OEM Rearview Camera wiring harnes from Acura. I replaced the entire wire harness to solve the issue but the camera still does not work. All fuses are checked and good, reverse lights work, light bulb in hatch door is working. No damage in wires between the Camera and new wire harness. That leaves me with a possible bad Rearview control unit (havent been able to find this yet) or a bad camera assembly. Maybe some other internal wiring issues between display and control unit. I've tried to take the passenger side interior panels off but saw it was going to be a pretty big job so I thought I should ask before I gave up. Please help. I have a cheaper volt meter, has red and black lead, but haven't learned how to use or read it yet. I wish I knew. The main difference I have noticed between others that have been able to fix their problem by reconnecting the wires is that their screens are blank, which indicates they just aren't getting power to the camera. My screen flashes between white and black about every second.
May 25, 2016 | Acura 2004 MDX Touring with Navigation S
Car Audio & Video Logo
225 people viewed this question
Top Acura Car Audio & Video Experts
xxxxxx xxx
afairman1927
Marvin
Marvin
Are you an Acura Car Audio and Video Expert? Answer questions, earn points and help others
