Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Ny Sony LCD projection TV has no color picuture.... everything is now in black and white...
legna
  • 53 Answers
SOURCE: my lcd tv is cracked
If you mind the lines and if they are too big replacing the screen will be very expensive and there is no way to repair your current display. The way I see it if you pay more 65% of the current value of your TV is too much. You may be able to find a new TV for as much as the repair cost.
Posted on Aug 28, 2007
  • 59 Answers
SOURCE: SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Posted on Oct 31, 2007
  • 84 Answers
SOURCE: Sony LCD Grand wega black and white picture
12000 hours you are lucky most last 2000 hours
lamp not the usual suspect for this
confirm black and white on all inputs and it will be more sinister, if only one input, it could be the signal source
Posted on Jun 22, 2008
  • 179 Answers
SOURCE: 60 inch Sony Grand Wega
no, it is not the lamp,the DIC 2 board is bad.in this case it is best to have a sony certified technician come out to give you an estimate. the board is expensive and the lvds cables attached to it are verrrry
fragile and expensive also.
Posted on Feb 06, 2009
  • 58 Answers
SOURCE: kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Posted on Apr 25, 2009
Black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Jan 23, 2010 | Sony KP-51WS510 51" Rear Projection...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Kdfe50a10 Sony lcd projection TV. No red color
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
LCD Sony TV - Skwiggly line
Hey there I think the problem is coming from your LCD chips not your bulb, the bulb has nothing to do with the color or skwiggly lines it just shoots out white light,your LCD chips are burnt and the problem will not stop by changing your light bulb you need to replace the OPTICAL BLOCK the skwiggly line will just get worst with time
hope this helps
please rate this solution !!!!
Oct 12, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
COLOR
Some people have a scale on their T.V. somewhere, or for most cable users it shows on the menu an area where you can change contrast, color, tint, brightness, ect...
Dec 08, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
82 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
