Question about Velodyne CT-120 Speaker
Blown amp need repair.. one a 1998 Velodyne 18 inch sub
  • 124 Answers
SOURCE: No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Posted on Mar 26, 2009
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
  • 124 Answers
SOURCE: Velodyne subwoofer HGS12
Not able to help you in Brazil
Contact Velodyne via their web site
Posted on Dec 20, 2009
  • 124 Answers
SOURCE: connecting amp back to subwoofer on a velodyne spl 8
You will need to contact Velodyne.
  • 124 Answers
SOURCE: hooking power amp to back of sub
Contact Velodyne.
Should have been a sheet in the box with amp for this
I have the velodyne DLS4000R and it keeps popping at high volumes ??
Popping ????? if popping sounds mechanical: chek for speaker blowned (replace or repair speaker)
if popping sounds electronic: chek circuitry.
Apr 03, 2011 | Velodyne DLS4000R Subwoofer Speaker
Do you repair velodyne fsx 12 subwoofers
what is wrong with it ? is it the sub ? the sub surrounds ? the amp ?
more info please :)
Jan 27, 2010 | Velodyne SPL-1000 Subwoofer
I have connected the subwoofer to the pre-amp out
One of two things may be going on.
The amp has a fuse mounted on the PC board. The fuse may be blown.
The speaker may be bad. that may have blown the fuse.
You can test the speaker with a "D" battery.
Take the amp section out of the back, disconnect the speaker leads.
Touch the speaker leads to the poles of the battery. it should make a little thump and the cone should move freely.
Contact Velodyne for service.
Dec 21, 2009 | Velodyne CT-80 Subwoofer
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
I just bought a used Velodyne hps 18 subwoofer. I am hearing popping sounds even at idle. What might be causing it?
This is related to the "servo control" circuit.
For repair you will need to contact Velodyne.
Nov 16, 2009 | Velodyne HGS-18 Speaker
When powered on speaker pushes all the way out
The problem is in the Amp. Velodyne is the only place you can get it repaired.
You will need to contact Velodyne for service
Mar 20, 2009 | Velodyne SPL-1500R Subwoofer
Hooking power amp to back of sub
Contact Velodyne.
Feb 28, 2009 | Velodyne SPL800R Subwoofer Speaker
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
Dd-18 no sound coming from it...
You could try disabling the auto-on feature or you could try a factory reset or firmware upgrade.
Swap the wires between subwoofers to see if its the wiring.
If its no longer under warranty you could try swapping the amp modules or the fuses, this will tell you if its a fuse or the amp or the driver... however by doing this you risk blowing up the second working amp or voiding warranty.
Last year I had an amp failure on my velodyne and it cost 250 for a 2007 replacement.
Dec 05, 2007 | Velodyne DD-18 Subwoofer
Velodyne CT-120 Speaker Logo
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
