SanDisk Sansa e250 MP3 Player Logo
Posted on Apr 23, 2008
Cant remove songs
When i go to my computer to go to my sansa files like video and pictures and music all the files pop up but music files so i cant remove my songs from my player. how do i get to my sansa music files so i can remove songs i dont want anymore?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
154
Points
Try opening it up in rhapsody or windows media player and delete the songs through there.:
  1. open either rhap or wmp
  2. the devices should be in a tab to the left (rhap) or on the top (wmp)
    1. for wmp, it might be in a tab in a tab
  3. click on the music "+"
  4. and from there delete the music
Cant find my music files
Go into settings and change the USB setting to MTP. Then Music file should be visable in My Computer.
http://www.sansaworldmp3.com/
http://www.sansaworld.com/
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Deleting from mp3
There are a few different ways to delete songs off your player.
Preventive Medicine: To prevent Windows Media Player from adding all of your My Documents files to the Sansa player every time you connect the Sansa to the computer - Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Set up Sync". When a window pops up, uncheck the box that says "Sync device automatically".
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Slow Method, allows more control over what gets deleted: In Windows Media Player 11, the files are organized by Music, Pictures, Videos, Etc. First, you will want to plug the Sansa player into the computer. Then click the Library tab in Windows Media Player. You will most likely be in Music view. You will see two sets of folders in the left-hand side of Windows Media Player. The first set are all the files stored in your computer. The second set of folders underneath the line that says Sansa 1GB Mp3 player (I forget the exact wording) has all the files that are stored in your Sansa player. Click on the "All Songs" folder. You can individually delete all the songs that you want by left-clicking once on the song name in the middle of the Windows Media Player window, and then pressing "Delete" on your computer's keyboard. You will have to repeat this process again for images, videos, etc by clicking the little arrow next to the picture of the musical note on the upper left hand corner of Windows Media Player, and expanding the dropdown menu, and selecting "images"...then "Videos" etc.
NOTE: After plugging in your Sansa player, if you see a message that says "Connect a Device" in the Sync tab on Windows Media Player, then the cmputer is not properly recognizing your Sansa player, and you may need additional instructions from me.
-Tha Mp3 Doctor
Sync problems ...
The instructions with pictures are on pp. 13-19 of the user's manual:
Loading Music
You can transfer music from your computer to the Sansa player using the dragand-
drop method or using music managing software like Windows Media Player.
Drag and Drop
Follow these steps to drag-and-drop music to your Sansa e200 player:
1. Connect your Sansa e200 player to your computer.
initial connection.
3. Double-click on Sansa device.
4. Double-click on the MUSIC folder.
5. Drag and drop music files from your computer to My
Computer\Sansa e200\...\MUSIC.
Before you can create playlist and transfer (or synchronize) them to your
Sansa player, you need to show Windows Media Player where your songs are
located.
Adding Music Files to Library…
1. To add music files to WMP 11’s library, please follow these steps:
2. Click the arrow below the Library tab.
Loading Content 14
3. Make sure Music is selected then click Add to Library…
4. In the Add to Library dialog box, click one of the following options
then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your
personal Music, Pictures, and Videos folders, as well as any files
stored in the public Music, Pictures, and Video folders that everyone
who uses your computer has access to.
- My folders and those of others that I can access:
personal Music, Pictures, and Videos folders, the files stored in the
public Music, Pictures, and Video folders, as well as the files stored
Loading Content 15
in the personal Music, Pictures, and Videos folders that belong to
other users on your computer.
Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
1helpful
2answers
Can't remove songs from mp3.
if you want to remove ALL songs from you sansa go to my computer right click the icon that refers to your sansa model and click format. this will delete all pictures, videos, voice recordings, preset radio stations, and music. this is the only way i have find to delete music permanently. before doing this make sure you have your files backed up. also you must be in MSC mode to do this.
SanDisk Sansa e250
Well the SONGS folder might be hidden [happened to me]
Steps to see hidden folders:
-My computer
-Tools
-Folder options
-View
-Show hidden files and folders
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
2answers
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
