Question about Lexmark X3350 All-In-One InkJet Printer
Im trying to figure out how to use the fax feature on this system
    Genius:
  • 1,087 Answers
Just make sure the computer is connected to a fax modem. Here's the Lexmark X3350 User's Guide to give you instructions on how to send/receive faxes. Just click on this link: http://bit.ly/dl0rJ9 to download. Scroll to Faxing for the instructions. Thanks.
Posted on Jul 28, 2010
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
Transmission
This is a strange problem you have here my friend. I found the manual if you need it. it is located here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX575.pdf If you cannot sort it out with the manual, I suggest that you contact Brother USA and see if they can assist you. their telephone number should be on page 1 I think Good Luck
Jun 12, 2007 | Brother FAX-575 Plain Paper Thermal
On my activity report, under comment is states TX ECM I know the TX is transaction (I think?) what does ECM stand for
ECM (Error Correction Mode)
The Error Correction Mode (ECM) is a way for the fax machine to check the integrity of a fax transmission while it is in progress. ECM transmissions are possible only between machines that both have the ECM feature. If they do, you may send and receive fax messages that are continuously checked for their
integrity.
Sufficient memory must be available in your FAX/MFC for this feature to work.ECM (Error Correction Mode) Detects errors during fax transmission and resends the page(s) that had an error.
If you have Call Waiting, RingMaster, Voice Mail, an answering machine, alarm system or any other
custom feature on a single phone line with your fax machine, it may create a problem sending or
receiving fax data.
For Example:
Your Brother machine handles the Caller ID and Call Waiting/Caller ID subscriber services.
However, if you subscribe to only Call Waiting or some other custom service and its signal comes
through the line while your machine is sending or receiving a fax, the signal can temporarily interrupt
or disrupt the fax data. Brother's ECM feature should help overcome this problem. This condition
is related to the telephone system industry and is common to all devices that send and receive
information on a single, shared line with custom features. If avoiding a slight interruption is crucial
to your business, a separate line with no custom features is recommended.
Jan 20, 2011 | Brother IntelliFAX 2800 Laser Fax
Will not send or recive fax
To test the fax setup from the product control panel, follow these steps.
  1. Press the power button (c01658021.gif ) to turn off the HP fax product.
  2. Wait 20 seconds and then press the power button (c01658021.gif ) to turn on the HP fax product.
  3. Connect one end of a two-wire telephone cord to the telephone jack and connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product. Figure 1: Two-wire telephone cord c01501963.gif Figure 2: Connect the telephone cord to the 1-Line port c01664685.gif 1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
  4. Make sure that there is plain white paper in the input tray.
  5. Press the Setup button (c01371950.gif ) on the product control panel.
  6. Press the down arrow (c01664686.gif ) to select Tools , and then press OK .
  7. On the Tools menu, press the down arrow (c01664686.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
  8. Review the report.
    • If the test lists faxing issues and solutions, the fax test failed. Follow the steps on the printout to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the fax test after fixing the listed faxing issues to make sure the test passes. If the HP fax product still cannot receive a fax, go to "Solution two: Make sure that the Auto Answer feature is turned on."
    • If the test does not show faxing issues and solutions, the fax test passed. Continue to the next solution.
NOTE: Click here (c00261105) (in English) for more information on interpreting the fax diagnostic test page. Solution two: Make sure that the Auto Answer feature is turned on The Auto Answer feature must be turned on for the HP fax product to receive faxes automatically. Turn on Auto Answer using these steps.
  1. Press the Setup button (c01371950.gif ) on the product control panel.
  2. Press the down arrow (c01664686.gif ) to select Basic Fax Setup , and then press OK .
  3. On the Basic Fax Setup menu, press the down arrow (c01664686.gif ) to select Auto Answer , and then press OK .
  4. Press the down arrow (c01664686.gif ) to select ON , and then press OK .
  5. Try to receive a fax.
Nov 02, 2010 | HP Officejet 5610 All-In-One InkJet...
I can fax using my printer - donot know how to
sorry I botherd you - I did not have the phone line in corrctly
when I figured it out the fax worked fine
Oct 02, 2009 | HP Office Equipment & Supplies
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
Want to FAX with My MagicJack(VOIP) using a standard FAX machine
holy ****, just google 'magic jack fax' and you'll get all the info you need. digital, analog, who cares, just do it.
Jan 01, 2009 | Computers & Internet
FAx & modem config
hi kababayan!
i think it's on VoIP feature...
please visit this site for more info:
http://www.microsoft.com/windowsxp/using/setup/learnmore/crawford_02october21.mspx
hey, what company do you work for?
Apr 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Lexmark X3350 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
