Question about Brother LS-2125 Mechanical Sewing Machine
Wont pick up bobbin thread
I have threaded it correctly but it still wont pick up the bobbin thread
  • Brother Master
  • 7,365 Answers
1.check needle to see if it's bent or blunt end
2.check bobbin & bobbin case for lint or loose thread
3.could be a timming problem- would have to be serviced
Posted on Jul 29, 2010
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Posted on Feb 18, 2009
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. (I don't try to straighten or "fix" damaged needles. With today's computerized machines, it may cause more damage than a new needle would cost. That may work on the old mechanical machines like the Singer Featherweights, but my machines are too important to risk for the price of a needle.) If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
Needle will not pick up bottom thread
Try a brand new needle. Verify it is installed correctly.
Remove the bobbin. Check that the bobbin is turning the correct direction and the thread is threaded correctly in the bobbin case. Reinstall the bobbin case and make sure that it latches.
Retest your machine. Manually turn the handwheel and watch the needle descend and see if the thread picks up the bobbin thread. If not, then the machine may have a timing issue. Take it for service.
Nov 01, 2016 | Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Aug 21, 2016 | Sewing Machines
I need a repair manual or need to know why when i try to sew it wont pick up the bobbin thread
The easiest thing to try is replace the needle with a brand-new needle. If the needle is bent or damaged, it may not be engaging with the bobbin thread correctly. Also make sure it is installed with the flat side facing the correct direction. Be sure to Raise the presser foot before threading the upper thread so it will seat properly in the tension disks.
Perhaps the following will offer some help:
Sewing Machine Needle Not Catching Thread
Needle not picking up bobbin thread Threads Magazine Gatherings Forum...
If there continue to be problems, the timing of the needle and hook could be off.
Dec 20, 2015 | Sewing Machines
Bobbin thread wont pick up
Refer to the manual to be sure the bobbin is feeding the thread in the correct direction.
Mar 25, 2010 | Singer Deluxe 57825 Mechanical Sewing...
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Oct 02, 2009 | Singer 7444 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
355 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
