Question about Power Acoustik TS980-2 2 Channel 980W Synchronized Lightning Pulses Plasma Sphere Amplifier Car Audio Amplifier
It keeps blowing a fuse - Power Acoustik TS980-2 2 Channel 980W Synchronized Lightning Pulses Plasma Sphere Amplifier Car Audio Amplifier
  • 323 Answers
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Posted on Jul 28, 2010
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
My crank fuse keep blowing what cause it to blow
Ignition Switch / Starter Fuse keeps blowing. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurusAug 14, 2010 - Ignition Switch / Starter Fuse keeps blowing. - I own a 2002 Ford Focus, 2.0l SPI engine. 5-speed manual trans. Recently bought from a friend's ...
Jul 28, 2015 | Cars & Trucks
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
Cop fuse keep blowing on my 2000 lincoln ls
I just got a lincoln ls v8 and fuse #12 cop's is missing what is this fuse for thank you
Mar 02, 2012 | 2000 Lincoln LS
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Car Audio & Video Logo
175 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
