Question about Dell 1720dn Laser Printer
Rollers make a loud noise when printing...do we need new rollers
    Problem Solver:
  • 5 Answers
Does it make a groaning sound, when picking up the paper from the cassette tray? If it does, sounds like you need to order a set of feed rollers. You can tell if there worn down, just by feeling if there's still some treading, just like a bald tire. Good Luck!
Posted on Jul 30, 2010
2 Suggested Answers
BaronVonNuke
  • 1915 Answers
SOURCE: When printing, makes a loud noise, like rattling
If the sound is coming from the back, this is likely a failed fuser bushing. If your printer has less than 150,000 copies on it, you can probably get the fuser replaced by HP under an extended service advisory they have for this product. Any service dealer can perform this free repair but you may have to make them aware that it exists.
Posted on Mar 11, 2011
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
When I am printing, there is a loud noise. Like something is not rotating correctly. Everything prints good, but that noise is really loud. It seems to happen when it feeds paper.
Hello there,
If there is a loud and buzzing noise inside it, the encoder strip, or the one that guides teh cartridge must be dirty. this causes buzzing sounds and mis alignment.
another is the rollers having too much paper residue in it.
i would recommend for you to clean the rollers with a lint free cloth and some water (just to dampen it)
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
Drum squeaks, squeals, have taken it apart. belt still has print and is not worn.unbelievably loud. how to get rid of noise?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Once you have taken the dryer apart and you will now remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
This should solve your noise problem.
For this FREE answer, Please rate me
Oct 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
HP 870Cse feeder/roller is dead
Take a very small amount of Goo Gone on a paper towel and roll it over the rollers. You can press and hold the top button to get the rollers moving. This will revitalize the rubber rollers. My printer is over ten years old and I do this about every two years and never get a misfeed.
Dec 08, 2009 | HP Deskjet 870cse Printer
Ge dptg750ec make loud rumbling noise after replacing blower
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Dell 1720dn Laser Printer Logo
1,150 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
