Question about Dell Inspiron 1150 Notebook
My dell inspiron 1150 powers up and works sometimes all day and other times it will turn itself off after 5 to 10 minutes, you can power it back but it will shut back down sometimes 5 to 10 minutes or it runs all day with no problems
  • 10,319 Answers
Check the output voltage to the charger. If ok replace the battrey instead. A faulty battery will shut the unit down at anytime
Posted on Jul 28, 2010
Laptop will not turn on.
Bad motherboard. Black Christmas is around the corner. New laptops are running 200-300. Time to save up for one...sorry :(
Nov 21, 2009 | Dell Inspiron 1150 Notebook
1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Jul 27, 2009 | Dell Inspiron 1150 Notebook
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
My dell insprion 1150 do not boot
BEFORE YOU REMOVE ANY DEVICES FROM YOUR COMPUTER REMOVE THE BATTERY AND AC ADAPTER.Pull the battery out and try using the ac only,if this works use a toothbrush and clean the contacts on the battery and the computer itself.You can also remove the memory and the cd rom plus the hard drive.see if it will power up with all these out.Last option with all these removed press and hold the power button down for twenty seconds.
Good luck
Apr 15, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
1150 won turns on then shuts off
Intermittent power on and off indicates a power supply failure. Check your power supply to make sure if it is working fine.
Oct 06, 2008 | Dell Inspiron 1150 Notebook
My computer laptop just shut down and will not turn on
Sounds like the power jack on the motherboard is bad. If you plug the power in and it doesnt show that it is charging (light indicator on the front) then that is probably the issue. Your choices are purchase a new motherboard or do like I did and order a 15$ replacement piece on ebay and resolder it in yourself. Its tricky to do but I managed to get through it.
Jul 15, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Wont Start Up
try taking out the memory.you can have the instructions by going to this link---http://support.dell.com/support/edocs/systems/ins1150/sm/upgrades.htm#1105389.Incase that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Dec 22, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
