Question about Astar LTV-27BG 27 in. LCD Television
Screen goes dead after startup, but sound works
  • 11,361 Answers
It can either be the 24vdc power supply is bad due to bad DC filter caps, or shorted out inverter board, those are the two places to check, please read below to do some testing first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 28, 2010
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
Nothing comes on my screen, using HP Compaq 420 Notebook, it starts up the system, but nothing is visible...thanks
If you hear any sound from computer..like the startup sound then it might be possible the lcd is not working....else try F8 at startup check if it goes to advance boot options..you can do power flee in which remove the battery for 5 minutes...insert it back and the then check..please rate if you find it helpful...thanks
Aug 12, 2011 | Computers & Internet
We cannot get the motherboard to show up using the current graphics card. The graphics Card is good. We tested it on another machine. The screen is just blank. Startup doesn't reveal a sound either.
sounds to me in my exp. that the motherboard is dead or perhaps the pci/agp slot mybe dead i would be looking at replacing the motherboard hope this helps
Mar 17, 2010 | Computers & Internet
Stuck on startup screen
Sounds like you are not getting past the BIOS
You need to boot from a floppy or cdrom/dvd that has some type of startup files.look for fdisk run it but be careful
what you are looking for is a partition that is marked as innactive.
maqke sure that it is marked as active.
Nov 15, 2009 | Everex StepNote NC1500 Notebook
Startup screen goes black.
I would try having the firmware reloaded or updated. Sounds like a problem there. Try going to xbox.com and downloading the update for playing older xbox games. This also updates the firmware.
Joe
May 20, 2009 | Microsoft Xbox 360 Console
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
No booting
plz try with new power supply
May 22, 2008 | Computers & Internet
Astar LTV-27BG 27 in. LCD Television Logo
49 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
