Canon mx 700 Keeps telling me paper wont print from front tray. I loaded several papers on top to print. Ive tried unplugging it and still same problem
    Brigadier General:
  • 3,917 Answers
Hi
May be the paper tray is setting to tight against the paper pushing it tight up to the front of the tray. Back the rear support up so there is maybe 1/16 inch clearance between the paper and the end of the tray.
Slid the rear clamp back to adjust the distance.
Please read this article bellow if it gives you any help or an idea…
http://files.support.epson.com/htmldocs/r380__/r380__ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=probsolv.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
FRONT PAPER FEED
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Feb 05, 2009 | Canon PIXMA MX850 Multifunction Printer
"Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Dec 03, 2008 | Sharp MX-2300N Color Copier
Loading paper from top.
there is a button to press to swap it from the back tray and the bottom tray. it sounds like you might have some thing stuck in the rear feeder causing the paper not to go through. i would try it from the bottom feeder and see if it works,
might be worth turning the machine off and unplug it and then try turning it upside down and shaking the machine, to see if anything come out of it.
If not i would say to take it apart or call a service engineer out.
Hope this helps
Oct 20, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer won't accept paper in tray
try to load about 20 sheets of paper.try perform reset..unplug the power cable at the back of the printer then press and hold the # and 3,insert the power cable and if you could see that the printer is starting to boot-up you can now go ahead and release the buttons.but if the issue is still occuring the printer paper sensor is defecte=ive and needs to be serviced/replaced......,,
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Not reading paper
If you toggle the Feed Switch button (lower left side of control panel) to the Front Tray, does the printer print then? What type of paper is selected in your Printer Settings on the computer? I think that if you have selected anything but Plain Paper, the driver wants you to load the paper (photo paper, etc.) in the Rear Tray.
May 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
23 people viewed this question
jasbo
jasbo
