Question about Admiral AAV7000A
My admiral Capacity plus model LNC6766 makes a bad noise when agitating. The noise is less when in slow/slow mode and gets worse as you go to normal/normal. I believe it is the transmission. My transmission is under warranty. Can you show me how to uninstall and reinstall the transmission.
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
SOURCE: My admiral capacity plus washer
I had this happen last year to mine. Check the hose that goes to water level adjustment switch. It may have a hole or crack in it. It may be small and hard to find but if there are any leaks in this hose the switch cannot sense the water level because it works on pressure through the hose to the diaphragm on the switch. You will need to remove the top panel of the washer to access this. I was able to replace the hose with some I had on hand. Saved me big $$$!
Posted on Jun 07, 2009
Yozzer6821
  • 116 Answers
SOURCE: Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Posted on Jan 05, 2010
Testimonial: "Great feedback. Will try suggestions. Thanks."
award462
  • 395 Answers
SOURCE: admiral capacity plus washer and dryer manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
I have a Admiral Capacity Plus washer LNC6267B71. Washer makes loud grinding noise when agitating & spin cycles. Machine does fill, drain, agitate & spin. Only noise is concern.
Hello. Your symptom describes damaged bearings and/or a damaged transmission. This is a MAJOR, INVOLVED repair requiring special tools to prevent serious injury during dis-assembly and re-assembly. I strongly suggest acquiring outside service to repair this machine if cost effective. There are many parts that have to be removed and then replaced--if you've never done this--don't attempt it. There is a brake spring with 200lbs of torque on it that has to have a special tool mounted to relieve the tension during removal and then re-compress it during replacement for example. Sorry to be so dramatic but I don't want you to get hurt needlessly. I hope I helped you!
Nov 05, 2015 | Admiral Washing Machines
There is cloth stuck under the aggitator on my Capacity plus Admiral washing machine. Model #lnc6766B71 how do I remove the aggitator
As a general rule Admiral is a VERY inexpensive machine, so you may be better off with a new one if the parts prove expensive. MAKE SURE TO UNPLUG MACHINE.. Be careful the agitator doesn't come loose suddenly when you are removing it, I have seen more than one bruise on the face from this.. hold your head to the side when pulling it off. http://www.rakerappliancerepair.com/NephewClub/Diagnostics/Washers/Maytag/Maytag%20TL%20Bulletin%20TDL-0086-B.pdf
Jul 06, 2015 | Admiral Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Agitator comes off during cycle in my admiral capacity plus washer. How do I fix it?
If the bolt is still on top. it was probably screwed too tight and wore through. then you need a new agitator
Sep 22, 2011 | Admiral 32 cu. ft. Washer
Washer won't agitate or spin
i believe this is what we call a direct drive system 2 things it could be is the drive coupler located under unit between the transmission and motor .it is a plastic piece with 3 prongs on each side and a black rubber bushing that goes in between each side to connect ..it is somewhat like a shear pin on a tractor it is designed to break when to much pressure... before you check this make sure the unit is making some sort of noise when it is suppose to agitate or spin..you should hear the motor running just won't spin the tub... if you are not hearing anything then i would suspect you have a bad lid switch on the unit... the lid switch is like a safety switch while running if the lid is raised the unit will stop power supply to motor ...you can check the lid switch byby passing it temporarily and see if it works .... one of the 2 may be your issue.... good luck to you
Feb 11, 2011 | Admiral 32 cu. ft. Washer
Nov 25, 2009 | Admiral AW22 Top Load Washer
Oct 26, 2008 | Washing Machines
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Admiral AAV7000A Logo
114 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
