Question about Maytag Refrigerators
Fan is not running can we fix this ourselves - Maytag Refrigerators
    President:
  • 1,099 Answers
Hello.
You can test the fan motor. Unplug the refrig. and hook up a temporary power cord directly to the disconnected motor wires. If it is OK, clean the coils of lint build-up, disconnect the wires attached to the relay plugged onto the side of the compressor. Pop the relay apart and see if it is fried inside. If so, buy a new relay or kit, about $50 and reinstall it.
Note that
That fan keeps the compressor cool. Without it the compressor shuts down early. You should be able to easily change out that fan by getting one at an appliance parts dealer. On line you could go to www.repairclinic.com to order one.
Good luck
Posted on Jul 28, 2010
I have a Sharp 1874 microwave convection oven. When we try to use it, it sounds like there is a fan hitting on the left side as you look at it. Is there anything we can do ourselves to fix it?
If you are handy you can fix it. It is just a plastic blade on the fan. It may be as simple as the fan motor came loose and moved. You have to look at it to be sure.
Dec 25, 2014 | Sharp Microwave Ovens
Freezer and refrigerator not getting cold but motor running
What is the make and model of your fridge?
Mar 31, 2014 | Refrigerators
Repairman was out on Staurday to fix 70" SONY KDF70XBR950 7
Yes an the projector unit also has channels around the fan that may be clogged. Also dust buildup on the bulb can cause erratic fan.
Apr 13, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
The heat in our 2003 Chevy Malibu will only work on the two highest settings. Is there anything we can do to fix it ourselves?
first of all remove trim under glovebox. then loosen and slid the pcm out of the way. you will then see the fan and resistor, resistor is beside fan motor. remove resistor and if need be replace it. if resistor is bad then you will not get all fan speeds. there is a coil for each speed. good luck carl,
Jan 07, 2010 | 2003 Chevrolet Malibu
Motor still runs--sounds like jet engine. do I need a new motor? or is there some sort of muffler that has malfunctioned? vacuum belongs to disabled mom---so trying to do work ourselves--cant afford much....
This little vac I think is actually made by Samsung. If it is ROARING and vibrating, either the bearings or suction fan is in bad shape. Remove the lid as if to inspect the belt and see if there is a visible intake opening with a plastic fan rotating inside. If so you have to inspect for damaged fan blade . A broken blade will cause the noise you describe and can be fixed on most vacs by carefully opening the fan housing and unscrewing,the fan from its threaded shaft. Then screwing on a new matching fan. Post back with more info and I`ll try to walk you thru the process
Sep 13, 2009 | Bissell 3590 CleanView Bagless Upright...
Door and rubbers are extremely hot and we are burrning ourselves while opening and taking food out
Your refrigerator has a stopped up Condenser Coil that needs cleaning with a vacuum cleaner. Also check that the Condenser Fan is working. The Condenser Fan may be bad....It sits under the bottom of the ref near the compressor and runs to cool the compressor. Hopes this helps! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jul 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
The compressor wont go on outside but the inside unit fan is working. it will not get cold.
This could be caused by so many issues,It would be best to call a Heating and air company for a service call.
May 31, 2009 | Fujitsu Heating & Cooling
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
