How do i connect my advent roma3000 laptop to my tv(its an older tv,only scart socket) iv been told it can be done,can you tell what cables i need and how to do it please.
  • 11,896 Answers
They have monitor to rca jack cables. they also have s-video to rca type cables.
Everything can be found on amazon.com
Posted on Jul 28, 2010
How do i hookup a sanyo vhr h607 to my television
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Oct 17, 2014 | Sanyo VHR-H607 VHS VCR
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Hello, i have a sanyo lcd tv & i want too connect my Advent Laptop to it, but i dont know what cable to use because my laptop doesnt not have the HDMI port or the VGA port.... help?
Does your TV have an S-VIdeo input? Does your TV have a DVI input?
What model of Advent laptop?
Does your laptop have a S-Video output socket (looks quite similar to a PS/2 mouse-socket) ?
Does your laptop have DVI-output?
Aug 03, 2011 | Computers & Internet
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
Where do i plug the different leads in the back of my tv i havn,t got a yellow port for the yellow connecter
What sort of tv do you have, is it new? If its new it may well have an Hdmi connection which gives you the sweetest graphics....
If your tv is older you probs have a scart connection, the yellow lead carries the video signal, some tv's have three little socket that the red yellow and white leads plug into if you cant find anywhere to plug it in you will need one of these , a scart adaptor
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120439215212&category=11319&refid=store
(thats just an example of what one looks like, you can buy them all over)
THe red white and yellow cables plug into the scart adaptor which usually plugs in the back of your tv, done
Jul 29, 2009 | Microsoft Xbox 360 Console
Connecting to tv
Use the TV's remote-control to select "input" from the S-Video port, rather than from the TV's own tuner (or from your cable-box).
May 31, 2009 | Advent Netbook
CONNECTING ACER TO THE TV
Please tell me what operating system you have installed and what the specs your machine are,
Can you also discribe to me how you have the computer connected to the tv thanks
This will help me understand your problem better thanks
Sep 06, 2008 | Acer Aspire 5100 Notebook
Connecting a T22 Laptop to a Matsui television
you’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need. The solution you decide on will be determined by your budget, and the prices and codes below are taken from here, so shop around and you may get a better bargain locally or online.
First, you need two separate cables for video and audio: S-video to S-video (£3.60, 35551), and Stereo 3.5mm plug to 2x RCA plugs (£2.80, 35491). Both cables are two metres long and longer cables are also available from the same site. Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter (£3.25, 35570).
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Mar 02, 2008 | IBM ThinkPad T22 2647 Notebook
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
