Question about Brother Office Equipment & Supplies
It does not print anymore,even with new ink cartridge. Can I purchase a new print head>
    President:
  • 567 Answers
Hi there yes you can purchase new print head go to http://www.google.com/search?hl=en&q=print+head+for+brother+printer+and+fax+machine&aq=f&aqi=m1&aql=&oq=&gs_rfai= and choose your model.
Posted on Jul 28, 2010
Lexmark 6500 series has cartridge error
User genuine cartridges to avoid this type of error.
>> Remove the print cartridge
>> Clean the print heads of the cartridge.
>> Re-insert it and check the status.
>> If the cartridge is already used (I mean 70% of ink) please replace with new cartridge.
Nov 18, 2013 | Computers & Internet
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Error code 0xc19a0023
I went crazy trying to fix my HP D7560, days and days of print ink failure, unable to align cartridges, until to clean print heads. My symptom is that the black ink started to print only in a light gray. I tried everything from running Tools, changing to new cartridges, even buying a new print head (which was not genuine HP, they don't make them anymore, and the new print head would'n't complete in diagnostics without error). I love this printer and didn't want to part with it. So I searched for days and tried many solutions without success. Until I found this one last solution - it my last ditch effort. The solution is to get a bowl of very hot water (not boiling), remove the print head from the printer and place the print head directly in the hot water (sounds risky! but I did it). I watched as the bowl filled with black ink. The instructions said to let it sit for 5-10 minutes, but I couldnt' believe the amount of ink that poured out of the print head. So, I kept replacing the water and shaking the print head carefully in the water to loosen the trapped ink. I repeated this step (replacing water) until it was no longer producing black cloud of ink and water was fairly clear. I carefully dried the print head with a paper towel, let sit for approx 5 minutes to dry some more, shook it vigorously a few times to shake out any water, and then lastly hit it with a blast of compressed air to ensure all water droplets were gone. I put the print head back in, re-inserted the cartridges and the printer ran through diagnostics automatically - aligning cartridges and printing a test page - it was BEAUTIFUL!!!! Until I tried this, nothing worked. I'm hoping this solution will help others. Good luck.
Feb 15, 2011 | HP Photosmart D7560 InkJet Printer
Ink Refill
You have refilled the ink that is why it reports low ink.
The explanation for this, is that the ink cartridge estimates the ink level by using the number of pages you have printed. Once you have reached a pre-programmed number of pages, the ink cartridge reports that it is empty; but it is not necessarily empty.
If it prints then continue printing. However, it will always give a low ink warning. Remember to get it refilled once the pages start getting missing text (or graphics).
If you cannot print, then you will either have to purchase a new cartridge or ask the person at the refill shop to reset it, if it is possible.
Sep 18, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Epson photo 995 - black ink not printing
This is a common problem I have found with Epson printers. If you don’t use the printer on a regular basis the printer heads can clog. I have found no way to clean the heads once this occurs. I will now only purchase HP printers because the printer heads are part of the ink cartridges. With every cartridge change you get new heads, end of that problem!
Mar 09, 2009 | Epson Stylus Photo 895 InkJet Printer
Canon bjc-85 printer doesn't print anymore
Have you tried changing the green carrier? That solved my problems with no ink.
Dec 04, 2007 | Canon BJC 85 InkJet Printer
All colors not printing
hi this is nichu, you have done everything correct but the ink is low in your catridges refill it or purchase a new one.
Nov 20, 2007 | Canon MultiPASS F80 All-In-One InkJet...
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
