Question about Vizio VX42L 42 in. LCD TV
Can't see picture
I have a vizio 32 inch, when I turn it on I can't see any picture, I can hear the audio but as far as picture it does not work. Does any one have a solution for this problem. I already checked for any unplugged cable but everything seems normal.
  • 11,361 Answers
You either have bad 24vdc power supply or shorted out backlight inverter board, those are the two place to look, dead T-CON board can cause no picture on the screen, the screen will glow slightly.
Please read on:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 28, 2010
When I go to turn on my Vizio 32' Model VP322 HDTV10A, it half turns on then back off, repeatedly for 3 minutes before turning on. How can I fix this problem?
If you are not able to hear sound during the this process, the power supply of the TV is likely failing.
If you are able to hear sound during the 3 minute ordeal, then likely the inverter for the backlight is failing, which can also be caused by a failing lamp as well.
Try this: turn the TV on, wait for it to do its thing. Goto the menus, picture settings, and turn the brightness *down* as far as it will go. Exit out of the menu (save if prompted). Turn the TV off, wait a bit, then back on. If still same issue, it could be the power supply or inverter / lamp assembly. But, if the cycle is shorter, or comes on right away, then it is likely the lamp / inverter.
Jun 23, 2010 | Vizio VP322 32 in. Plasma TV
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
WORKED FINE WHEN TURNED OFF, THEN NO SOUND WHEN TURNED ON
1. I would first make sure that correct "INPUT" setting is registered.
2. Try a different input source such as VCR, DVD or CD.
3. Connect a pair of audio RCA cable to all the VIZIO set's audio inputs one at a time and touch the center tip while the set is powered ON and the input is set to the corresponding seting. If audio circuit is OK you should hear a hum with at least one of the input settings..
4. If still no audio, then it maybe the audio circuit board needs to be checked.
May 15, 2009 | Vizio L32 32 in. LCD HDTV
There is a popping sound about once a minute on our Vizio 32 inch
It sounds like a ground wire or something bad in the Audio board. Send it in for repair
Mar 16, 2009 | Vizio VW32L 32 in. LCD HDTV
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
GE television
My GE 32 inch won't come on, when you turn it on you can hear click two to three times then it comes off.
I have another 32 inch GE TV that has no picture except white/gray light on the picture tube, but there is sound
Oct 20, 2008 | GE (-25001RE2) Audio Conference
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
May 19, 2008 | Vizio L32 32 in. LCD HDTV
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
Vizio VX42L 42 in. LCD TV Logo
172 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
