2,2 error is short protection in this model.
WHAT IT MEANS IS ONE OF THE TWO FUSES THAT PROTECT THE CONVERGENCE CIRCUIT IS BLOWN; This model uses 2 of the STK-392-570 CONVERGENCE chips---
I have photos of the fuses etc--fuses and chips are located on the middle circuit board which would have to be removed to repair. I also have step by step start to finish instructions for this repair in this model.
If the parts needed are purchased on EBAY (I can tell you the name of a seller there) total parts cost is under 25 dollars and repair takes about one hour.
Many shops will not do this repair in the home and most will get 250 plus for it not counting pickup and delivery.
How handy are you? I can post the instructions and photos here if you respond to this answer by "add a comment".
SD TECH
Sounds like my problem exactly...would like to get the instructions.
I am interested in getting that information so I can repair this dreaded blinking light issue please send the instructions.
I am having the same issue can you send the instructions? Thanks.
Ditto on having same problem (now I have 2 dead big screen TV's). Kindly send repair instructions.
need a email address as if I post them here others will copy them without my permission.
email is [email protected] Thanks!
I have a WS-65909 with the same problem. Can you please email them to me at jkdeep6 at yahoo dot com? thanks.
If it's not too late would you please send instructions and pictures to [email protected] I have the same 2-2 problem on my Mitsu WS65909
I am having the same problem I soldered all new capacitors in my d m bored but it is still doing the same thing error code 2 - 2! can you please send me all of that information to [email protected] for a w s 65
Wrong stk#
SOURCE: Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
SOURCE: mitsubishi ws-65807 no sound or picture
Something related to the video boards. Check all inputs first, then check ribbon cables to the video board. Be careful of high voltage if you open the cover.
