Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
Have a sta rite vertical MSF pump for my irrigaion. The pump motor stop working and i noticed after pulling cap of that it turns real slow and hums then trips internal breaker and motor gets hot? Replaced hard start selonoid and no fix? seems to be in windings? any help or diagnostics? Dont see any overheated wiring or part from the outside or under cap! Thanks Steve
    Brigadier General:
  • 3,917 Answers
Hi
Check the bearing, if that is stuck.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
  • s14p Jul 28, 2010
    motor turns easily by one finger no binding !
  • s14p Jul 28, 2010
    bearing is fine motor turns over freely!
Sta rite pro jet 3/4 hp seems to be frozen..turn on and it hums then quits ..no water pressure
it sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Jun 25, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Sta-Rite 1HP inground pool pump Every time the pump turns on it trips the breaker, after taking the motor appart and lubing it up I could get it going but once off for a period of time on startup it will...
Any time an electrical appliance trips a breaker there is only several causes:
1 - appliance is pulling more amperage than the breaker was built for.
2 - breaker is faulty
3 - a "hot" wire is touching "ground"
4 - screws (where wire is attached) in the pump or breaker are loose
1 - If the appliance is pulling more amperage than the breaker (or wiring) will allow, then check the appliance to see what amperage it's rated at. If this is more than the breaker will allow, you'll have to plug the appliance into a circuit that will take that amperage. If the appliance rating is within the limits of the wiring & breaker, then check #2, #3 or #4 above. If everything is okay with the remaining possibilities, then you have problems within the pump. Do it yourself'ers usually have a bad time when they open an electric motor. I suggest you take the motor to a electric motor repair shop or seek help from the Sta-Rite pump Customer Service.
Jul 01, 2010 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
Pump hums then breaker flips
Something is binding in the pump try the impeller to see if it runs true when you have it apart. It may be cross threaded on the shaft. This is a common problem if you have a air leak in your system.
Apr 28, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Reset button for sta-rite well pump kicks off
That could be a bad wire in the well or the pump motor has a flat spot...or a spot that if the motor stops there it will not start....also could be that the pump bearings are worn and the motor locks up once in a while...
Bottom line the pump will need to be pulled and probably replaced....
http://www.fixya.com/support/r3755320-electric_problems_submersible_pumps
heatman101
Apr 22, 2010 | Plumbing
Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Nov 02, 2008 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
136 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
