Question about RCA D52W19 52" Rear Projection Television
RCA D52W14 Cable connector on the ITC 222 and ITC 222A signal
RCA D52W14 Cable connector on the ITC 222 and ITC 222A Small Signal Board is broken off can't connect the cable to it to get TV signal, Do i need to replace the whole board or can i find that part where the cable connect and replace that?
  • 171 Answers
A good experienced tech might be able to do it for you .  other than that you will have to replace the SSB
Posted on Jul 28, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
No just buya new rf connector and soilder it on or some times it the old one is not in bad shape you can reuse it but mke it soilder on very good and the board is ok no cracks some people pull and wiggle them arround until the brake them e
Posted on Apr 27, 2012
Cable connector broke off
You should be able to get a replacement Small signal board from www.tvrepairworld.com
Nov 15, 2011 | RCA HD52W59 HDTV Projection Television
No audio
ok sound on the rca itc222 chasis comes ofd one curcit board. This board is called the small signal board. but before we get this replaced we have to elemate a few things. one check you audio setings and make sure the amplifer is set to internal. also you speakers could have blown. and the connectors to speaker unlikely be loose. If these items are elemanted then the small signal board. a item that only technicians can replace. they have special computer interface they use to download data from the old to a new board when they replace it
Jun 04, 2011 | RCA HD52W56 52" Rear Projection HDTV
We have RCA Model HD52W59 and the input cable end broke; is that replaceable?
Its possible to resolder the Connector but its a vert precise soldering. Its often easieast to replace the small signal board . You can get small signal boards from www.tvrepairworld.com
Nov 05, 2010 | RCA HD52W59 HDTV Projection Television
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
Replace the small signal Board
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound went out on my RCA D52W20 rear projection HDTV while watching it.
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO SOUND at all!
The audio is controlled by the small signal board, which is very costly and hard to get, however I will post a link where you can get one for about half price. Its called the ITC small signal board and its actually a sale item at this site. Heres the link.
http://servicemanuals.vstore.ca/
Sep 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
Help me
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
245 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
