Question about Philips Magnavox 27MS343S 27" TV
How do I do a channel scan? - Philips Magnavox 27MS343S 27" TV
  • Philips Master
  • 5,586 Answers
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Posted on Jul 28, 2010
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Incomplete Auto Scan of the channels
I ran the Auto Scan. Before the scan reached 91%, I pressed the Menu button on my remote and all of the channels that it found locked in.
Jan 07, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
No Channels found after scan for new channels
was it working before ?
Are you on cable ? run your scan in cable mode
Are you on an Antenna run your scan in air mode
Dec 04, 2009 | Televison & Video
Channels are different than my old tv!
you may be able to do a manual scan ion each channel which is similar to auto scan.
Its normal for auto scan to select random channels when scanning.
May 07, 2009 | Philips 19PFL5622D/37 19 in. LCD...
I have a MTX8000 Handie-Talkie FM Radio It is a 16 channel radio
You're on scan mode but have no channel in scan list. You might have to go to scan PROGRAM mode and select the channel you want to scan then press a side button to put that channel in the scan list then will scan.
radcom907
Mar 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Philips Magnavox 27MS343S 27" TV Logo
350 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
