Welcome Back
You can simply buy a product to do this and most certainly will work if your tv does have a scart connection.
Here is a link to a example of a product that will work:
http://www.amazon.com/Lake-Converter-compatible-Windows-S-Video/dp/B00351VWKI/ref=sr_1_8?ie=UTF8&s=electronics&qid=1280277383&sr=8-8
Click the link above allow me to also give you a picture and a mental note.
Here are some pictures with diagrams to help you:
Hint you can also use the RCA for the TV instead of a projector! So the diagram is really a guide to help you in your situation and not to be taken seriously as to it only can go to a projector. You would use a scart connection or what its called RCA the yellow one the other two will not be used as those are for sound. This cable you can buy at radio shack for under $1.50 a foot.
Thanks a whole buch for your questions and I hope my answers do help you in your issue. You may reply to me or you may press the accept button for my efforts.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
can i connect it to my tv without that box? could i do it with a certian cable/s? im a cheepo and dont want to spend £30-40 for that conversion box is there a cheeper way?
Because you got to down convert from VGA to scart you do need a box. Now you can aslo find these on ebay for under $20 bucks I was just giving you a idea!
Because of the down conversion the box will be needed now if you had a newer TV!! with a VGA port this box is made in that TV make sense?
Newer tv's have a VGA input on the side witch you still will need a long vga cable witch still runs about $25 bucks respectivly. You cannot just take a VGA to scart without down conversion.
Ebay I have seen them for under $20 bucks you might want to check over there.
Thanks
I found something but its a risk and is untested, Click here
http://cgi.ebay.com/NW-VGA-SVGA-TV-S-VID...
Do not shoot the messenger if it does not work now. But this supposed to connect and convert a vga to svideo and scart.
Thanks
As long as your laptoop's video card has TV out support witch it might now have due to rechecking you specs this may or might not work
link to the product HERE
The product will need again a long enought cable from the tv to the laptop witch still going to cost you something. $40 bucks is a little high for what I was talking about the unit was like $24 and change FREE ship witch was not bad. Now this conversion above is $under 5 bucks$ but might be a waste of your time.
thank for using fixya.com I hope we have helped you.
