Question about Maytag Dryers
I Have a MDET336AYW Maytag electric dryer. It tumbles and gets hot but makes an awful screech like a bearing or something it going out of it. Can you help me get it a part and find the problem?
  • 4,070 Answers
Part 2 and 3 on this diagram are the glides and felt pad which are used to support the front of the drum and when worn out you will have metal to metal rubbing.
Part 17 is the drum support roller for the rear of the drum. You have two of them.
You'll have to determine where the noise is coming from to know which is the problem. Using the diagram for the cabinet you can remove the front to access other parts. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174209&diagram_id=1362912#d1362912
Posted on Jul 28, 2010
Neptune dryer makes noise
Check the blower to make sure it is properly secured on the motor shaft. Also check all of the bearings: motor, tensioner pulley and drum support rollers or drum bearings. You may have to disengage the belt to check the motor and tensioner.
Oct 06, 2014 | Maytag Neptune MDE5500AY Electric Dryer
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Dryers
My dryer is not getting hot. The clothes tumble, but do not get dry because the dryer is not getting hot. Could it be the thermostat or something else?
First, check the venting to make sure it isn't stopped up with lint. This is the most typical case. Also, which you probably already have done, make sure the lint screen is clean. You may have to disconnect the flexible hose on the back of the dryer to clean your vent.
Apr 12, 2011 | Maytag Dryers
Electric dryer makes a screeching noise while
could be your pulley or rollers or the motor itself you have to take the entire unit apart and visually inspect where the noise is coming from could be rear bearing if the model is old enough if you are not mechanical i suggest you call a tecnician hope this helps
Jul 15, 2010 | Maytag Dryers
We have a three year old Maytag electric dryer. It has started a high pitched whine. Still drys and tumbles. Venting works well. Suggestions?
maytag dryer's are also amana dryer's.that has a main bearing in the back of the unit.this is the first indacation that your main bearing is going bad,.do a service call now and save your dryer.
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't start
check your circuit breakers for dryer they may have tripped whenlights went out. write back if not the problem let us know a little more about problem
Jan 30, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
My maytag dryer MDET336AYW won't come on
probably have a back door switch. look and see if when you close the door it closes the switch
Jan 04, 2009 | Dryers
Dryers Logo
232 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
