Must be a programming error. I have the same it says you must log in first everytime i try to log in. This is one of those problems that is just brushed aside untill no one cares. Try and download the facebook bookmark onto your phone again.
It's probably a browser or windows error if using IE - try using firefox or a different browser. Yoville also has occasional loading problems that generally get fixed fairly quickly. Stack overflow means the program has run out of memory space to store
parameters to - the solution to this would be to clear your browser and try login again. ( Internet options for IE or clear private data on firefox), then restart your windows. It also is possibly a java script error - you can update java for IE at http://www.java.com/en/download/index.jsp To fix IE6, usually there is a check box in add/remove programs, windows components, uncheck it, then recheck it and it will install IE again. If using IE6SP1, it will possibly be listed as a program in add/remove programs, simply click uninstall and it will then offer a repair or restore option, use repair. Restart is required. If using IE8, try going back to IE7, uninstalling will revert back to the 7 version. The 7 version works far better than 8. You might also try updating your flash player if the problem persists.
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer". I click yes and it says "Preparing to remove" then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not . Anyway please help
download free broswer, and install, do not import your Explorer settings
goto www.java.com
install the free java program
goto www.macromedia.com (it will take you to an adobe page, since they bought the company) on the lower right hand side of this page there is a link to download the free flash player.
close the browser. run the install firefox program, if you have not. run the flash install program, and the java install program if you have not. be sure to follow my order.
