Question about Vacuums
I am having trouble with threading and tension of Elna Contessa MO 103. Would you be able to help by sending me a pdf of the manual please? Thank you for your help.
  • 51 Answers
Http://www.tradebit.com/filesharing.php/search/0/elna/0/1
Posted on Nov 12, 2010
Adjusting the knobs on the front of my Singer 9005
If the bottom thread is showing through, back off the tensioner, 1/2 number at a time.
Jan 18, 2013 | SewShop.com 9005 Singer Instruction Manual...
Cant thread cotton correctly resulting in top cotton bunching around bobbin on my elna carina su sewing machine
Hi. Correct threading of your machine is absolutely essential for flawless function. I would suggest starting fresh, removing upper thread completely. For correct function, every threading point needs to be passed in the correct order. Every hole or thread guide should have thread going through it. Use a tweezer and pass the end of the cotton through each point, paying special attention to the tension discs and take-up lever. Double check to make sure you have light but firm tension on the thread (having lowered the presser foot, because tension is released when foot is up). Rotate the hand wheel slowly in it's normal direction to check function before attempting to sew.
Aug 20, 2011 | Vacuums
Cannot use my 1/4 inch foot as the needle is not positioned properly on my elna contessa 410
Set the stitch width to zero or set for straight stitch, as opposed to zig zag or button hole.
I have a Tacsew T11-115 and I do not have an instruction book. I need to see if I have it treaded correctly and how to adjust the bobbin tension. The top thread is laying on the fabric and the bobbin...
For all sewing machines, if the bobbin thread is showing on the top surface, then the top tension is probably too tight. Turn the tension indicator to the left by half a number to a lower value. (So that if 5 was lined up with the dot initially, then go to 4.5 lined up with the dot).
See this article for some clear pictures of thread tension adjustments: http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . If you can find it the Singer Sewing Book is a good reference http://www.amazon.com/Singer-Sewing-Book-Gladys-Cunningham/dp/0307098702 .
This site, http://www.allbrands.com/products/abc0762.html , may be able to find and send you a manual to the TacSew T11-115. They have the T11-155 for sale.
I hope this helps.
Jun 12, 2011 | Vacuums
Hi, My mom gave her machine to me but with no guide. It is an Elna 5000. Just need to know the following - I want to shorten a T-shirt but use the same double sticthing than the shop. It looks like...
Maggie,
getting hold of a manual is always a big help so I would suggest that you go to this page http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf and save this manual. It is for the 7000 which was released about 9 months after the 5000. It will have more stitches than yours but the threading up, accessories and look of the machine is identical to yours. These were the first computerised machines made by Elna Tavaro in Switzerland back in 1987/88.
May 31, 2011 | Vacuums
The bobbin thread bunches up underneath the garment on Elna 2004 sp
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Apr 08, 2011 | Vacuums
I have an Elna 745 serger/overlock machine. Whenever I'm doing a double cover stitch hem, when I'm at the end, the thread release lever does not release the thread. To release it, I have to cut the...
There are two methods to release the cover stitch with sufficient slack in the thread. Since you are using the thread release lever, did you set the Brown tension dial to zero? Before changing the tension, you have to first lower the needles to their lowest position in the fabric with the hand wheel and then turn the hand wheel backwards to bring the needles to the highest point in the cycle.
The other method may work better for you. Bring the needles to the highest point in the cycle and lift the presser foot. Then slide a thin object (a sewing ruler, for example) between the presser foot and the feed dogs and pull the needle thread towards you. Cut the needle threads Then pull the fabric away from you before cutting the looper threads.
Both of these options are described on page 98 of the manual, which is available from Elna. The current link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst_Book_745_%28E-F-G-I%29.pdf . Pictures for the second method are available here: https://www.seamwork.com/issues/2015/06/coverstitch-machines . (Ending the double cover stitch hem is the same as that for the single cover stitch.)
I hope this helps.
Nov 27, 2017 | Vacuums
White model no.765 I am having trouble remembering how to thread the machine.
I just received a
White 765 machine and it came with instructions on how to thread it. Send me your EM addy and I'll send you a PDF.
wayne448@yahoo.com
Jun 27, 2010 | Vacuums
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
