Question about Kodak EasyShare M1033 Digital Camera
My Kodak M1033 HD camera won't turn on. I haven't used it in a few days, and when I wanted to it won't turn on. It is charged and everything, the last time I touched it I was charging it. It was working perfectly fine before. What could be the problem?
5 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Kodak M1033 shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 09, 2009
shockwave727
  • 262 Answers
SOURCE: Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Posted on Nov 09, 2009
leepania
  • 1099 Answers
SOURCE: have a kodak m1033 that seems to be frozen in the
All Technical equiptment can have problems Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 21, 2009
SOURCE: I have a Kodak M1033
go to : http://www.fixya.com/support/t5301378-kodak_m1033_lenses_stuck_open
i did it at it works now but you have to remove the front metal case(4 screws on teh sides) and blow the air
bonne chance
Posted on Aug 07, 2010
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
Camera won't work
my camera does the same thing! did u fix it somehow
May 21, 2010 | Kodak EasyShare M1033 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak m1033 switching itself off
There may be any of the three fault in your device.
  • Battery got died up (Need to replace)
  • Your Charger may be faulty, try to charge it through USB Cable by connecting it to your system (computer), I case your camera have facility to charge it from computer.
  • ON/OFF switch may be malfunctioning (shorted).
Else, Your device need service (repair)
Have a nice day Rating the solution is highly appreciated.
Mar 05, 2010 | Kodak EasyShare M1033 Digital Camera
My M1033 will power on and then it just powers
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare M1033 Digital Camera
Its turns on beeps then shuts off
Aug 05, 2009 | Kodak EasyShare M1033 - black Digital...
What is the method to know the batttery charge is completed
Download the Kodak M1033 manual from the following link
http://safemanuals.com/user-guide-instructions-owner-manual/KODAK/M1033-_E
it provides in for on battery charge status and any other info u wud need about this product
Jun 27, 2009 | Kodak EasyShare M1033 Digital Camera
When I turn on my Kodak EasyShare M1033 the screen is black.
"My sister thinks it's probably because I dropped it to much (which I do)"
"I even smacked it a couple of times."
Simple NEVER buy another camera again!
Mar 22, 2009 | Kodak EasyShare M1033 - black Digital...
Kodak EasyShare M1033 Digital Camera Logo
598 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
