Question about GE Refrigerators
My GE profileModel # PDS22SFSALSS serial #ZH041895 My referigerator is running constantly. I changed my water filter followed the complete procedure I now do not have a green. This refrigerator was purchased December 2005
  • 4,070 Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jul 28, 2010
We just changed out filters in out K5 unit and turned on the water and the faucet and the water is running very slowly. What can we do to get it running strong again
Your manual is here:
https://www.kinetico.com/media/2329/13034j_manual_owners_k5_1216.pdf
Did you follow the filter change procedures completely and correctly including depressurization? Did you change the pre-filter - probably clogged? Did you open up the faucet fully?
OK. Now be patient! Wait for the tank to fill. With a maximum filtration rate of 3 gal per hour, it will take 5 min to produce the first quart.
Aug 23, 2017 | Plumbing
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
Ge referigerators
check water hose for a kink in hose
Aug 27, 2012 | Refrigerators
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
GE referigerator stopped working all of a sudden
Main board on back of refrigerator has gone bad. Costly part but is easy to change out as long as directions are followed. Hope this helps.
Jan 28, 2010 | Refrigerators
I have a GE referigerator Model # GSH25KGRE of 4 years old... I hear a constant click-click noise coming from the back/motor..and I suspect the temp in the freezer is slowly dying down..
The clicking behind the refrig , is comming from the main control board , behind the 8" X 10 " panel . The part number is WR55X10656 . The compressor relay , on the board has burnt . Yes , your freezer is thawing , due to the clicking .
Sep 23, 2009 | GE Refrigerators
How do I change the water filter on GE side by side TFX25CRWW?
Here is a link to a free downloadable owners' manual. Go to page 6 for complete instructions on how to change the water filter...
http://genet.geappliances.com/DocSearch/pdf/49-6953.PDF
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
My Fridge is less than 2 yrs old. Yesterday I heard a clunking sound coming from the fridge
to clunk,
i have a GE model PDS22SFSALSS & it did the same thing...blinking LED & clicking, then LED went blank. i read that GE was having major problems w/ the mother board, (cost for part $ 153.75 & $79.95 for service call, they couldn't tell me the labor cost!! )on many models & were re-calling some. i called GE repair 4/8/08, got no help, then i called customer service & gave them my model & serial #. they said my box would be fixed (mutha bd swapped) for free. i bought it 10/05, they came the next day & installed new board free! start w/ GE 1-800-432-2737 .....good luck
denden8148@aol.com
Nov 30, 2007 | GE PDS22SIS Bottom Freezer Refrigerator
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
