Question about RCA P61940 61" Rear Projection Television
Colors arnt lined up and it has an hour glass shape....but i cant find tne auto conversion or whatever its called, in the menu i need help!
  • 171 Answers
Can't fix that with remote.  sounds like convergence circuit has died.
Posted on Jul 28, 2010
My 2000 chevy suburban interior rear view mirror is loose at the adjustment section it drops down and seems loose to the touch when trying to move it up but secure at the section that is attached to the...
If you are referring to the mirror mount on tne windshield..there is a small hex screw on tne underside of tne mount that tightens the mirror to tne mount..just find the size very small and tighten it..ask at any of the auto parts stores..the screws are pretty much the same..Good luck...
Mar 04, 2015 | Cars & Trucks
RCA 52 HDTV Projection color is going in 3 different ways like I'm looking in an hour glass!! Does anyone have an answer???
very easy repair on that model depending on wether the auto convergence option is still listed under the setup menu options. Let me know if its still listed and I will assist you with the issue.
Mar 29, 2012 | RCA HD52W59 HDTV Projection Television
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
The colors seperate and there's hour glass shaped lines over the
you have lost convergence in your set. although i find it rare to have the fl231 fuse problemon this old ge model i always check to see if that the first thing at the shop. there is a article intitled fl231 problem in tips and trick section. the next thing will be the convergence power supply. if yu have the convergence option in the setup of customer menu under red or blue convergence can you move the crosshairs
Apr 23, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Stretched screen
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Oct 05, 2008 | RCA P61940 61" Rear Projection Television
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Tv picture shaped like hour glass
Big cap in the regulation ckt is bad. Depending on model could be various values, a shop could use their ESR meter to find and replace it.
Jul 03, 2007 | GE 31GT740 31" TV
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
RCA P61940 61" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
