Question about Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
Bar not recieving oil
Chainsaw bar is not getting any oil from tank
  • 699 Answers
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Posted on Jul 28, 2010
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Chainsaw chain keeps getting tighter when using?
this is a sure sign of chain overheating , due to not enough oil to bar , this will eventually cause bar to wear down and chain to not stay on
ck your oil pump and oil tank for proper operation
Aug 25, 2015 | Husqvarna 435 - 16" 41cc Consumer Chainsaw
How to correct no oil flow to bar on Model172.34120
ive not done much with this model but I can give you some basics on why I see lots of chainsaws loose there oiling of bar
(1) Wrong oil used in supply tank- most all chain saws take 30 wt bar chain oil . this is a lite/fine oil and needs to be so it flows thru small ports and pump on saws
(2) fine sawdust in supply tank - I guess anything can fall in the tank but I do find theres a lot of junk that falls in there over time , if it don't flow like oil does then it don't belong in the tank
(3) sawdust jammed in bar ports this id say is the biggest one I find , seems sawdust (all different size pieces) finds its way into the fine ports that oil is suppose to flow thru , sawdust mixed with oil makes a darn fine plug !!!
other than these simple things above , most saws have lots of parts that can break and fall off look for something just not right looking and sometimes it will be very obvious whats missing
Jul 19, 2015 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have borrowed a chainsaw PWR1750CSA from a friend i need to know what oil goes in the tank, i presume it is to lubricate the chain.
The fuel tank takes a 25-1 fuel oil mix, the oil tank takes a non fling chain oil to lubricate the chain, if you you a light oil it will spray off the end of the bar and not lubricate the under side of the bar where most cutting is done, if you cannot get non fling oil use as thick an oil as you can get hold of.
Sep 08, 2011 | Garden
Chain turns but comes loose and burns at wood. also get alot of smoke from chain area
Insufficent chain oil to the bar, check there is oil in the oil tank, remove the bar and clean out the delivery hole in the bar.
Jun 15, 2011 | Poulan 14" Chainsaw
Poulan PRO chainsaw -- oil is not getting to bar...what could be the problem?
You need to remove the bar and chain, clean out all the oil delivery holes in the bar, if no better drain the oil tank, fill with a suitable cleaning fluid and rinse out the tank, this will help to clean any dirt from the pick up filter, now try again, if still no better, you will have to remove the clutch and sprocket to gain acess to the oil pump itself
Apr 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No oil to bar
Drain the oil tank, now will witha suitable cleaning fluid, rinse the tank out several times, this will help to remove any dirt in the oil filter screen, remove the bar and chain, clean out the bar rail and oil feed, now try again.
Mar 05, 2011 | Poulan 14" Chainsaw
I have a older remington gas powered chainsaw (model SL16)- I rebuilt the carb (new diaphragm and gaskets), started it , did some adjustments and it ran great- When adding bar oil to the bar oil tank and...
An impulse line from the crankcase pressurizes the oil tank to force oil to the chain. On the bottom of this line in the oil tank is duck (one way) valve. I think it has failed (open) and you are sucking bar oil into the crankcase. Loosen the oil cap before putting her to bed to help stop the bar oil from weeping. Key word Help. LOL HTH
Lou
If this doesn't solve your problem try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Do a search for your saw it has probably been asked and answered. They will help if my suggestion doesn't work and you can't find an answer.
Oct 20, 2009 | Remington Garden
Stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Apr 14, 2009 | Garden
Chainsaw bar studs
empty out oil tank . you have to tap old stud out through oil tank.replace same way can be tricky but you should be able to get back in
Sep 28, 2008 | Husqvarna Chain Saw 20" Bar
Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
1,551 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
ray gallant
Joseph Hoffmann
Are you a Stihl Garden Expert? Answer questions, earn points and help others
