Question about Samsung CLP 315 Laser Printer
TENGO UNA SAMSUNG CLP-315 PERO YA NO ME DEJA IMPRIMIR ME APARECE LA QUE ERAL LUZ VERDE EN COLOR ROJO QUE DEVO DE HACER GRACIAS
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
SOURCE: refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Posted on Mar 08, 2009
  • 14 Answers
SOURCE: Samsung CLP-315 eats toner. Cartridges last almost
Note if you have the latest 2009-version of the clp-315 printer it's important you get the newest version of the resetchip.Since the old ones doesn't work with the new.
simple_life_2 and buyorsell66 sells nice items on ebay for this kind of stuff.
Posted on Sep 08, 2009
Lin0
  • 6 Answers
SOURCE: how to refill toner cartridge for Samsung CLP-315
Yeah actually theres "something" about this particular toner cartridges...check this out: http://sites.google.com/site/refillinstruction/Home/clp-310-refill
Posted on Dec 19, 2009
SOURCE: CLP 315 : USB Printer status is not available
There is a problem in your usb
Posted on Jul 15, 2010
No me carga el juego monster world
a un amigo no le carga el juego...le aparece "Bad Request
Your browser sent a request that this server could not understand."...que se puede hacer?.. ya formateo la maquina e instalo todo de nuevo pero no hay caso...por favor espero una respuesta gracias!!
Oct 29, 2012 | wooga - world of gaming Monster World
NO APARECE MI CAMARA WEB QUE VIENE INCORPORADA A LA LAP, COMO LE HAGO, DICE QUE NO SE ENCUENTRA O QUE ESTA OCUPADA O QUE NO TENGO, QUE DEBO COMPRAR UNA Y ESO NO ES POSIBLE, POR QUE SI TENGO CAMARA WEB,...
que hago tenia instalado en mi pc oficce 2003lo cambie por 2010 pero cuando quiero reproducir una presentacion de power poit dice que no se encuentra el punto de entrada del procedimiento except handler 4 common en la biblioteca de vinculos dinamicoas de msvcrt.dl que devo de hacer por favor quien me puede ayudar
Feb 24, 2011 | Computers & Internet
Cambie el filtro por uno nuevo y la luz sigue prendida en rojo como cambio a color verde
Una vez que filtran la luz se vuelve roja, sigue siendo rojo hasta que se resetea. Para restablecer el indicador del filtro, presione ambos LOCK y DISPENSADOR DE AGUA
botones simultáneamente y mantener durante 4 segundos. Hacer luz verde que parpadea tres veces cuando el indicador
se restablece.
Feb 05, 2011 | Maytag MSD2655HE Side by Side Refrigerator
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Samsung CLP 315 Laser Printer Logo
138 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
