Question about Woods 59007 Decora Style 3015105 Minute Preset Wall Switch Timer White
Woods timer how to conect with 2 wires woods timer
  • Woods Master
  • 5,245 Answers
Copy following link:
http://waterheatertimer.org/How-to-wire-timers.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 19, 2013
2 Suggested Answers
CaptAdams35
  • 28 Answers
SOURCE: my woods timer has ground
First off, it's a Canadian product, so we have to do everything in reverse.... Just kidding! The results could be shocking ~ no pun intended. You'll need to exchange your timer for another one not requiring a neutral wire.
Posted on Jul 30, 2010
I have a junction box with a 3 way switch that operates hall lights, and a 2 way switch that operates outdoor lights. I want to replace the 2 way with the Woods timer (59018). I tried following...
Remove timer, and reconnect both switches as they were before starting.
Notice if there is a wire that connects to both switches... this will be the Hot wire.
Then notice that the 2-way switch has two wires.
One wire will be Hot > and this wire connects to timer Black wire.
And the other wire goes to Load (light) > and this wire connects to timer red wire.
The timer green wire connects to bare ground wires.
This leaves the timer White wire > you can connect timer White wire with the other ground wires.... > or look in the back of switch box to notice a group of white wires covered with wire nut > connect timer White wire to these other white wires.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59018
Gene
h
Oct 28, 2013 | Coleman Cable Woods 59018 InWall 7Day...
I'm looking for a timer to replace the thermostats for 2 furnaces in a riding arena.
1) Yes a spring-wound timer will work.
Woods 59717, Intermatic FD60, etc
There are other models depending on length of time, and color of timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
2) How to wire to 24 volts
24 volt circuit has 2 wires going to load.
Cut one of the wires and then connect cut wire to timer.
3) Buy Woods 59717 or Intermatic FD60 timers at Amazon.com in home improvement.
Both products have 1 year warranty, and both are strong companies.
Spring-wound timers last many years, and set-times are approximate.
Jan 03, 2013 | Woods 60 Minute Spring Wound Timer in...
Is the Woods 59028 Programmable Timer Switch Light Almond a 3 way switch?
Woods 59208 is single-pole timer.
Open following link to see list of timers used for 3-way application:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
When replacing 3-way switch, some timers can replace either switch. For example Aube and GE.
Other timers can only replace switch that receives power from breaker. For example Intermatic.
The timer replaces only 1 of the 3-way switches.
The other 3-way switch remains.
But in all cases, the remaining 3-way switch has to be rewired to accommodate the timer.
3-way timers cannot replace 3-way switch wire-for-wire.
3-way timers mimic 3-way operation. When 2 of the timer wires are connected, the timer reverses programming. When those two wires are disconnected, the timer programming resumes. So off becomes on, and on becomes off.
The remaining 3-way switch has to be rewired so that switch connects and disconnects the two timer wires that mimic 3-way operation.
Aug 08, 2011 | Woods 59028 Programmable Timer Switch...
Is the woods 59028 a 3 way switch?
I have the Woods 59018 In-Wall 7-Day Digital Timer, and am having trouble installing it. I am replacing an IntermaticModel EJ251 timer that only connects using two black wires in the junction box (as...
Open following link to identify timer, read wiring instructions, and download on-line manual:
How to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
I am replacing a light switch with a woods 59007 timer switch that has red, black, green and white wires.The current switch has only black, white and a bare wire and no other red or black wire. What do I...
1) Woods 59000 series in-wall countdown timer has extra wire to run electronic clock circuit inside timer, just like plugging in ordinary alarm clock.
2) Open following link for wiring instructions, and to download online manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
3) Instructions:
How to wire 59000 and 59017 in-wall timers
4) If electric box does not have white wires described above, then connect timer-white to bare ground along with green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 21, 2011 | Woods Hardware & Accessories
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
Timer was connected with all wires correctly. On/Off button is lighting up red, but does not turn light on or off. Directions said try switching switch from off to timer, but unable to locate switch. ...
Woods timers:
Scroll down page to make sure your timer is shown.
You posted under Woods 59018-59028
GE 15086 timer has OFF-Timer switch
http://waterheatertimer.org/images/GE-15086-programmable.jpg
http://waterheatertimer.org/Programmable.html#Aube
Add a comment to identify timer, and I can help more
Double-check wiring:
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
Nov 22, 2010 | Woods InWall 7 Day Digital Programmable...
I have a 59028 timer, and when I turn the lights on they flash - versus staying on.
59028 is a Woods in-wall timer.
See Woods timers and manuals:
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
The lights are blinking so the red and white wires are connected together.
Here's what to do Switch has 2 wires.
1) Green wire connects to bare copper
2) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
Nov 20, 2010 | Hardware & Accessories
Woods 59007 Decora Style 3015105 Minute Preset Wall Switch Timer White Logo
161 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Steve
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
