Question about Craftsman Garden
Have mower model 944365750,engine is "huntig" at full operating RPM,any suggestions. John
4 Suggested Answers
  • 2841 Answers
SOURCE: JD Z Trak 777 overheating
Drain the coolant, flush the system, replace the thermostat, and pour in a fresh supply of a 50/50 mix of antifreeze and distilled water. If it still overheats the water pump is suspect.
Posted on Jun 01, 2010
SOURCE: Toro lawnmower model 20027. The
"Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar" (baymee LehighValleyPA, 2009).
I'm going to try this tomorrow myself!
Posted on Aug 30, 2011
  • 6468 Answers
SOURCE: john deere model LA105, deck engagement cable spring keeps breaking.
are you routing it the right way rubbing or kinked
Posted on Apr 04, 2012
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
My john deere 3038 will not allow a parked exhaust filter cleaning
Needs to be moving and with a load to keep the engine warm and at operating temperature for at least 20 minutes. And full throttle..
Sep 25, 2016 | John Deere Garden
John deere pdf manuals
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer. The mower should have a dip stick like a car and it should be visable once you open the hood of the mower.
Jul 28, 2014 | John Deere D110 42 in. 19.5 HP...
Toro lawnmower model 20027. The engine starts fine, but goes to full rpms. I have closed the throttle with my finger but it goes back to full rpm operation. Everything seems fine on the mower. i just got...
Aug 27, 2011 | Toro Personal Pace CARB Walk Power Mower
Jun 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Sep 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
Mar 16, 2009 | Garden
Garden Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
