Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
GU980 dishwasher I have a buzzing sound when the washer is in drain mode. The manual indicates there might be something in the Power Clean Filter, and that it will go away when the object grinds up. I called Whirpool, and they said the same, and to run for 2-3 cycles to make go away. 2-3 cyles later, noise is still there. I noticed a nub off the rack that looks like an end peice of metal broke off from rust. My guess is it's stuck in the PCF, and will not grind up. I removed the nut, lower spray arm, and mechanism on top of the PCF (6 screws), and there's a round, rubber piece with a screw in the middle. This is where I got stuck. I cannot get the screw off to get to the PCF. I do not want to break it and have a bigger problem, especially when I don't know that will solve anything. Any suggestions? Thanks, Art
  • arodi Apr 28, 2008
    Thanks for your suggestion. I was able to get the impeller off, but nothing was inside. The washer still makes a humming/buzzing noise durng rinse & wash cycles.
    Any other suggestions?
    Thanks,
    Art
    Genius:
  • 1,073 Answers
The nut holding the inpeller has to come off it is probally frozen
if it snaps off then the pump assy willl have to be replaced or at least the motor, you need to get below the impeller to see what is down there though, or let it run as it is
Posted on Apr 24, 2008
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
I noticed just as going to bed last night that our dishwasher appeared to be making a strange noise (dull buzzing sound), opened door to check and the display has the number 3 flashing, several fault codes...
check the very bottom of washer; look for something jamming the garbage cutting blades. it can be something very small stock half way in the drain causing the blades to stop turning and therefore keeps it from draining water. just an idea
Dec 16, 2014 | Hotpoint-Ariston LFT 228A 23 in Builtin...
How to make dishwasher drain? Water stands in bottom after washing. Also has buzzing sound!
Most likely you have something hard that got past the filter and got stuck in the drain pump, keeping the impeller from turning. Unplug the dishwasher. Siphon or vacuum out the water from the dishwasher. Remove the toe-kick panel(s) to get to the drain pump. Look carefully for a realease tab to press, then rotate the drain pump 1/8th to 1/4th turn to release it. Check for and clean out any foreigh objects, then re-assemble.
Sep 16, 2014 | Kenmore Dishwashers
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Buzzing sound
a loud buzzing sound it is probably a faulty control/timer module.
If the appliance works the same, you can keep it like this, if it still under guaranty, call the number listed on the owner manual to get repair.
If you got the sound only recently, that means that the control is going to fail soon, in that case call a repairman and have the control assembly replaced.
You find diagrams and parts here,
just enter the model number.
Oct 10, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Does not drain
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Jun 18, 2017 | Kenmore 24 in. 17052 / 17054 / 17059...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
303 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
