Hi:
Yes you are correct you have a floating return ground on the main system control board, check all ground connections on the microprocess itself, you might take a light torch and try heating the micro area of the sys control board. There is no reset on this model its done by the microprocessor, but there is a reset lead on the micro which should read high while operating normally, Logic probe this pin while turning on the unit if it continues to stay hi even when turning off the unit then replace the Main system control.
Reset procedure is as follows:
Press Volume Up and Channel Up buttons on tv simultaneously and release.
Above procedure will set tv to default factory settings.
Click HERE to download service manual copy that will help you.
Did you tried to hook tv with computer on low resolution so it can turn On?
Thanks.
The manual is a users manual and doesn't do much good.. To clarify the TV is not coming on whether VGA or TV inputs. I tried connecting the vga with windows 7 but that didnt help. However, an interesting point .... Windows detected the TV with the proper model number and reccommended a resolution even with the tv not powering up. That tells me basic logic must be working. I tried various combinations of screen resolution down to 400 x 600 and including the one windows reccomendeds for this monitor (1368 /768) but still nothing happens the red light remains a steady on when the power cord is plugged in... and there is no picture or sound. it is not powering on..
The reset procedure you reccomended didnt make any changes and is probably for use once tv powers on.
I have found listing after listing on this model where people have plugged in the vga and the tv totally shuts down, but no solutions...
I thought it would be service manual but its user manual, sorry for that mistake.
This site offers service manual for small fee, check it out please.
In my opinion, it seems firmware got crashed when PC/VGA input selected that is why no options to return it back or cancel PC input.
Main board of TLA-04011C is available with Shop Jimmy for $275 and I think main board replacement will solve the problem because I do not see any firmware update option.
Thanks.
ok, no problem.
I agree with firmware possibility, but does anyone have info on firmware download? for this model.
