Question about Refrigerators
What capacitor needs replacing on the VT-12LEDS when it goes into the LED oscillaing on/off mode?
In mine it was the one near the conections to the cooler. its small, round and clack. is a Electrolityc capacitor, polarized, and 16V 1F
Posted on Aug 01, 2010
Tv turns on normal, after about 5-10 min loud screeching sound and tv goes blank, reset by unplugging and turns on normal again only to repeat the cycle.
Hi Laz
Televisions get power supply unit problems that do exacly what your describing.
It is Caused by ageing Electrolytic Capacitors.
If your not tech savvy then take it to a technician
otherwise
Find & Replace the Caps yourself
Try These
Switched mode power supply
How to Replace an Electrolytic Capacitor
Good Luck
Mar 14, 2016 | Hisense 40" Smart TV Full HD 1080p LED...
LG Led TV has sound but no picture, but when turned on it flashes the LG logo and goes blank.
You have a backlight inverter that goes in safety mode maybe you can replage any bulget topped capacitors in your backlight inverter print and then most of the time also in your power supply to find replace 16v for 25 volt ones of the same capacity the size of the capacitors can be a little different. It is not to late but there must be hurry because your step up transformers can be damaged by the too high voltage that pulsed by broken capacitors. if your LG is about 5 years old 80% shure there are bulget convex topped ones to find inside or leaking of that Korean brands Le Lon or Teapo or other Brands that have used by most Brands a
to tight tolerance on voltage .
Feb 14, 2016 | LG Televison & Video
Samsung 37" standby red led flickering
That doesn't say much, if its blinking won't turn on then sounds like the power board capacitors are shot and you need to replace the power board. Some time just one capacitor goes out and they will just replace the entire board.
Feb 20, 2015 | Samsung Televison & Video
How do i by-pass an imobilizer in a vt holden
you could leave the key in ignition in the on position for about 10 to 20 minutes this over rides immobiliser so you can start vehicle. the red immobiliser light that flashes goes out when you can start it. the light is the red LED next to the trip computer buttons
Oct 14, 2013 | 1999 Holden VT
I have a Bosch ksu 44 fridge/freezer which has stopped working - just a click,click,click from the back and the control board led's flash with each click (1.5second intervals) - is it the control...
Very common problem on that fridge and a easy fix: Replace the two big capacitors on the right side of the control PCB 1uF = 0,68uF 250V They lost their capacity causing bad uC supply and this strange LED blinking. Be aware that this blinking can be intermittent and the fridge appears to return to operation. But the uC suffer a lot of internal resets causing intermittent operation stops, low temperature and more not easy recognizable or strange mal functions. So, if You face that blinking normally the capacitors are gone. Some strange and intermittent behaviors of the fridge are also back routed to this PCB - Capacitor malfunction. So enjoy this 30min fix. The capacitors should not exceed US$2 in Your local electronic shop. If You don't want to spend the US$2 You can find the capacitors as a lucky guy in a old PC power supply.
For other more complex problems be aware that the controller board has a very nice and helpful self test option. You go in this mode holding the temperature select button of the refrigerator (not the freezer button) then switch the fridge on and stay on holding the temp button for more 10s. The self test sequence starts in the moment when You release the temp button.
LED 1: Checking sensors (Blinking=OK - Continues=NOK, something wrong)
LED 2: The Flap opens and close two times (Alarm LED shows the open and close position, so the led must go ON and OFF two times in accordance of the detected flap position from the internal reed contact. (So, no action on the Alarm LED no movement on the Flap or a defect Reed contact)
LED 3: Fan goes ON and OFF
LED 4: Drain Heater goes ON and OFF
LED 5: De- Dicer Heater goes ON and OFF
LED 6: Compressor goes ON and OFF
LED 7: End of test sequence - Initializing procedure of normal operation.
Every step takes 30s and the whole sequence take tree and a half minute. Be aware that the alarm LED is no malfunction indicator. It has only the indicator function for the sensors.
The fridge goes in the normal operation mode when he passed the sequence. No further actions necessary.
Be aware that every time when the fridge faced a total power lost he makes a short silent 30s check sequence. If he face a malfunction (Sensors or actuators) he doesn't start the compressor anyway to protect the fridge for further damage!!! So, this test sequence is a nice tool to check that the fridge is in the right conditions to start the working and even so to check the compressor function before maybe a unnecessary replacement .
With a second build in test option you can select and activate devices in the fridge. For this You hold the fast freeze button and switch the fridge on. After 10s release the button and you are in a manual test mode. With the temperature button select the component - Push the Fast freeze button to activate or deactivate. For example: Select LED6 (Compressor) with the temperature button, push the fast freeze button for ON and OFF. But I ask You to be careful on this test mode to avoid further damages. For example a blocked motor that You should release better by hand than blow up by a tricky fingertip. Enjoy this fix and feel free for Crtl C + Crtl V.
Jul 04, 2011 | Bosch KSU49630 Top Freezer Refrigerator
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
