Question about Yard Machines MTD Gold 20 HP Lawn Tractor 13AL771T004
Runs but when u engadge the blades it dies - Yard Machines MTD Gold 20 HP Lawn Tractor 13AL771T004
  • 4,070 Answers
I would try bypassing the safety switch on the mower at the bottom of the blade control stick. It's meant to prevent starting the motor with the blades engaged but it or another safety switch can be bad. You may have one for reverse, the seat and brake.
Posted on Jul 28, 2010
Scag turf tiger 61"
Check switch with ohm meter.
May 21, 2014 | Garden
Blades wont engadge belts on
This would be either the clutch relay, pto switch or pto clutch, check the relay first, then the pto switch, and lastly, check the clutch, if the clutch tries to engage with switch, then the switch and relay are good, and the clutch will need adjusted or replaced
Oct 16, 2013 | Mtd Garden
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
Were does the cable hook on the deck that engages the blades
you have to give more info
If its a manual engage the lever tightens up the belt by sliding a pully against the belt
If its an electric pto it has an engadge button and that powers up the eltric pto wich inturn runs the belt
Jul 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Constant clicking noise when i turn on the car & have the ac on
it sounds like the compressor clutch is engadging and dis engadgeing you may be low on refridgerant
Jul 08, 2009 | 2006 Kia Spectra
Engine dies when blades are engaged
sounds like one of the safetey switches are not working
Mar 22, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
1988 jeep 4.2 wrangler runs fine then dies.
Check the timing. also check the fuel system
Jan 20, 2009 | 1988 Jeep Cherokee
Starter runs but does not engage.
If the starter motor is running, but not engadging the engine you have a faulty bendix drive, which is what makes the gear in the starter engadge to the flywheel, then retract after the starter has been disengadged. It may just be in the celenoid, which is the small round cyllender on the side of your starter that engadges the bendix. If you remove the starter and bring it to an autozone or advance auto they can test it for you to be sure for free. You will also need to bring the old starter to them as a core, so if you bring it to them before purchasing the new one, they can test it and the core charge will be paid for when you purchase the new one.
Dec 17, 2008 | 2000 Chevrolet Cavalier
Yard Machines MTD Gold 20 HP Lawn Tractor 13AL771T004 Logo
543 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
