Question about Olympus SP800UZ Digital Camera
I have no manual for my new camera and when I pull up the camera initialization there is no program to start the process.
  • 922 Answers
Find the manufacturer's website. Download the manual for the model of camera you own.
Posted on Jul 28, 2010
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Have the SimpleTech SimpleDrive External 400GB hard drive. When I click on StorageSync I get the message "Program is already running. Can't create process". Don't know what to do? Any help?
    Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
    Oct 29, 2008 | Computers & Internet
    "failed to initialize" camerawindow-downloading images to macbook
    Do what the pros do...use a card reader to download to a folder you create on your desktop.
    Feb 20, 2010 | Canon PowerShot A470 Digital Camera
    353 husqvarna chainsaw, floods during start process
    Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
    Your Operator's Manual can be downloaded here:
    http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
    Once flooded Huskys are very hard to start. This works well on my 359.
    Start Procedure
    Cold:
    1. Ignition on/off to on
    2. Set compression release – optional step even if saw is equipped with a compression release
    3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
    4. Set compression release – optional step even if saw is equipped with a compression release
    5. Push (open) choke pull starter until it starts. (usually the next pull)
    Warm:
    3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
    4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
    Hope this helps
    Lou
    Oct 03, 2009 | Husqvarna Garden
    Displays sys error session manager initialization terminated unexpectedly status of 0xc00026c (0x00000000 0x00000000)
    smss.exe is the process that manages sessions in Windows Computer. This is the session manager subsystem, which is responsible for starting the user session. This process is initiated by the main system thread and is responsible for various activities, including launching the Winlogon and Win32 (Csrss.exe) processes, and setting system variables. After it has launched these processes, it waits for either Winlogon or Csrss to end. If this happens normally, the system shuts down; if it happens unexpectedly, smss.exe causes the system to stop responding (hang).
    In this case, I suggest that you start the "smss.exe" process manually from the Task Manager. You can press the "Ctrl+Shift+Esc" together to display the Task Manger window. Then, click on the Applications tab then the "new task" tab located at the bottom. In the New task dialog box, please type "smss.exe" and click OK.
    However, you can also perform System Restore to restore the Windows System files to the time when it operated normally. Performing System restore will not delete any saved data however, all the installed programs after the selected restored point will be unistalled and require to reinstall them.
    Jul 11, 2009 | Computers & Internet
    Screen reading memory card not initialized
    Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 31, 2008 | Fuji FinePix Z2 Digital Camera
    Card not initialized
    There are various free media recovery programs available as downloads from the net. They may help recover the lost data. Many camera stores offer image recovery as a service, also. Contact your local dealer.
    Jan 19, 2008 | Fuji FinePix F10 Digital Camera
    Olympus SP800UZ Digital Camera Logo
    175 people viewed this question
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
