Question about ASK Proxima C160 Multimedia Projector
Power We used the projector in the morning, then set it up at another location. The green steady power light came on. I hit the power button and it went completely dead. Waited an hour, still nothing when plugged in. Is there a fuse?
Thanks, Marie. If it was only that simple, I will have to remove the main board just to see the power supply :( But it helps to know that there is a fuse below it.
Posted on Apr 25, 2008
  • 563 Answers
Hi Harold L
Yes it is most probably the fuse that has gone.
Take of the top cover of the Projector and look on the Main Powersupply Board ( the one with the AC inlet on it ) - you'll see a fuse on the board.
Change the fuse even if you cannot see any markings or discolouration on it.
Good luck and I hope this is of help.
If this doesn't work - just post another posting and I'll respond ASAP.
Thanks for using Fixya !
Posted on Apr 24, 2008
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
The power button light flashing rapidly (white light NOT green)
OK - I had 100% the same problem, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Jun 08, 2009 | InFocus ScreenPlay 5700 Multimedia...
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
ASK Proxima C160 Multimedia Projector Logo
214 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
