Question about Dukane ImagePro 8935 Projector
My dukane 8935/8942 won't turn on. The standby light was red along with the lamp light. I let it cool off overnight but it still won't work. Help? I checked the bulb and it seems ok.
Flashing red temp and lamp lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 22, 2014 | Dukane 8912 Projector Lamp 200-Watt...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I push the power button standby light turns red & blinks 3 times 7 THEN TURNS OFF
If the standby light is flashing 3 times. (your post says 3 times 7) I was unclear... A error code of 3 blinks inidicate that the door covering the lamp is not secure oer the lamp is not secure. Make sure the lamp door is seculy screwed down. ussally the door push a little switch closed. If this doesnt work the next thing to try is to remove the bulb carefully(dont touch the lens) and replace it making sure the bulb is in place securely. let me know if i can help any further
Mar 04, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Hi. i just replaced the lamp in my t/v and after watching for about 30 minutes the t/v turns off with the red lamp indicator light. if i wait 30 seconds and press the power button it turns back on but only...
that wouldn't be needed to do. mostly it means if it's not the lamp it's a hardware problem call the mitsubishi parts 1-800 number they can fully further help you but when they tell you what part you really need look on ebay for the part and save some money
Jan 08, 2011 | Mitsubishi WD-57733 57" HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
LCD projector still not working after lamp change
Sounds like you have a faulty ballast. I recomend changing it. This is your lamps own power supply.
Apr 10, 2009 | Hitachi CP-X250W Multimedia Projector
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Oct 04, 2007 | Televison & Video
Dukane ImagePro 8935 Projector Logo
63 people viewed this question
Top Dukane Office Equipment & Supplies Experts
jasbo
jasbo
Jim Goldsmith
Jim Goldsmith
Denis J. Cabrera
Level 1 Expert
Are you a Dukane Office Equipment and Supply Expert? Answer questions, earn points and help others
