Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool washer model# GHW9200LW. When you start the washer it stays on add a garment for a long time and I hear clicking, doesn't go to the rinse cycle, you get an F display. Does this mean there's not enough water, the door isn't locking what? Some say you might have to change the screens on the hoses, or its the MCU or the CCU. I tried a test posted where you put the washer on drain/spin and get the C:00 the water empties and the washer spins but what does that test prove? The washer is eight years old put hardly used, the appliance store where I bought it suggested buying a new one, are they nuts. He did tell me to unplug it for 24 hrs. and try that and it worked one time. He asked if we had a power outage and I said no, but then I remembered we did have the power go out and come right back on. Thank you for whatever help you can give because I can't afford to pay out $300-$500, let alone buy a new washer.
When you hear more about this, can you let me know too.. I am having the same problem. jkfehr@telus.net
Posted on Sep 26, 2010
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
Oct 04, 2014 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Mod.ghw9200lw has f-02 code
This is a draining error code. First start by cleaning out the drain filter. This is done by removing the access panel on the bottom of the front cover. Make sure to check the hose behind the drain filter, as socks and small under garments love to hide there. Also check the impeller on the pump, if any tines are missing the pump must be replaced. If all is good with the pump, re-install the drain filter and run the washer through a rinse and spin cycle.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport Washer that will not start but stays in the Add a Garment stage with the door lock lamp lite. The door locks and I am unable to unlock the door and the cycle will not start. I...
Each time there is a major part swap - replacement - they switch the number to differentiate between the boards.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
STARTED WASHER, THEN HIT PAUSE TO ADD A GARMENT. WASHER WILL NOT START NOW. I HAVE EVEN TRIED TURNING IT OFF, BUT THE LIGHT STAYS LIT, AND THE WASHER WON'T START.
have you turned off the power and unplugged the unit for 5 mins?
plug back in and progress the timer to where you left off?
Mar 12, 2009 | Whirlpool GHW9400 Duet Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Won't restart or clear off
try unplugging for a few min adn replug see igf that clears the computer, you didinbt by chance force the door open to addd a garment didi you??? if so the door lock has probalby beed compromised
Apr 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
166 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
