Question about Olympus FE-240 Digital Camera
Protec. Escr. ¿qué significa esto?
"Protec. Escr." I have a problem with the Writing protection on the camera. What do I do in this case?
    President:
  • 942 Answers
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Posted on Jul 28, 2010
    New Friend:
La falla es fisica la platina donde se aloja tarjeta SD no la presiona bien para que la camara detecte el boton lock de la tarjeta de memoria presionarla suavemente para ajustarla un poco , en mi olympus fue la solucion
Posted on Aug 18, 2013
    New Friend:
Me sigue saliendo igual la camara y la memoria le doy para ambos lados y es igual k puedo acer?
Posted on Jan 20, 2013
  • 1 more comment
  • dulce_gotita
    dulce_gotita Jan 20, 2013
    me sigue saliendo igual la camara y la memoria le doy para ambos lados y es igual k puedo acer?
  • dulce_gotita
  • jesus Aug 20, 2013
    ajusta la platina donde se aloja la tarjeta SD para que quede un poco justa y el sensor de la camara que detecta el botoncito lock de la tarjeta se presione y la libere sino siempre va a salir el mismo error
SOURCE:
Kenwood protect
What model Kenwood device? May I assume it's not actually a camera?
May 14, 2013 | Cameras
10.1 megapixel
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 02, 2012 | General Electric GE J1050 Digital Camera
I need a solution please, the camera says protec escr and i cant do nothing, can you help me?
You didn't specify the make and model of your camera, so I'll assume it uses SD (and/or SDHC) cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2011 | Cameras
My camera Olympu FE-340 is locked, it got locked when i conected it to my laptop, i can transfer the photos i have in it to my laptop, but when i want to take photos the screen gets black and red letters...
Perhaps the protection slider on the memory card has slipped into the locked position, or is there a 'protection' or 'favourites' setting in the camera menus?
Dec 11, 2010 | Olympus FE-340 Digital Camera
Buenos dias tengo un problema con mi camara es una olympus con memoria xd picture card la prendimos y no podemos sacar fotos ni filmar nos aparese la palabra protec escr con signo de admiracion que puede...
Desde el menú de la cámara formatea la memoria.
Si no funciona, formatéala desde la PC.
Si no se formatea en una PC, la memoria está defectuosa. Compra otra.
Nov 09, 2010 | Olympus FE-240 Digital Camera
This camera displays an error that reads: PROTEC. ESCR
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 10, 2010 | Olympus Stylus 1010 Digital Camera
Al prender mi camara digital alympus dice protec. escr que hagO.?? pOr favOr aiiudaamee
When this problem occurs Protec. Escr., Just enter the tools menu and find "Format" and voila, the camera returned to work usually remains
Aug 27, 2010 | Olympus FE-240 Digital Camera
When i turn on my camera it says...WRITE PROTECT...and wont let me take pictures...what do i do
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the position farthest from the contacts protects the card from writing. If the slide is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try a different card.
Feb 06, 2010 | General Electric A835 Digital Camera
My camera is displaying on the lens WRITE PROTECT on my ge 7.0 megapixel A735
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts protects the card from writing, the position nearest the contacts enables writing. If the switch is already toward the contacts, slide it fully the other way and then back again.
Feb 04, 2010 | General Electric A735 Digital Camera
Olympus FE-240 Digital Camera Logo
2,993 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
