Digital loses and regains broadcast constantly on several channels.
  • dianeteetee May 13, 2008
    I don't know if its digital loss, I don't have an actual box on this T.V. but I do have digital cable. Channels 2-9 will shut off after a couple of minutes almost as if I lost cable. But the other channels no problem.
    Novelist:
    Scholar:
  • 100 Answers
Salutations Dragon01,
Are you using an antenna?
Unlike analog signals digital can be more demanding on reception, and if there is any fluctuation in the signal strength you'll get what I call "digital drop out"
If you don't have an antenna I would suggest investing in one (a powered antenna maybe needed depending on where you live). If you do have an antenna try repositioning it nearer to an outside wall or window.
If your concerned about having a big ugly antenna in your house, one of the neatest ones i've seen is available through BestBuy.com.
http://www.bestbuy.com/site/olspage.jsp;jsessionid=BV5LONCO1RUJJKC4D3PFAGQ?skuId=8408458&st=digital+antenna&lp=1&type=product&cp=1&id=1180743979527
Its a cherry wooden picture frame with a intergraded antenna!
Cordually
Jon
Go Ahead. Use Us.
Posted on Apr 23, 2008
Why is channel2 off the air
You would have to contact your provider for that information. Channel 2 differs in broadcaster and content across the nation. There is no centralized channel 2 broadcaster. My regional cable TV channels differ from yours.
The possible explanations are:
The station has shut down its transmitter for repair or upgrade or even being moved to a new place.
Co-channel interference. (You would have to re-scan your digital channel setup.)
A new man-made structure has blocked the "routing" path of the signal, i. e. is interfering with the RF signal.
But only your provider knows what else may have happened for you to lose a single station!
Nov 17, 2017 | Cars & Trucks
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
Samsung soundbar
I have found that most channels broadcast at different volumes, more so when it comes to commercials. Something I will never get used to, but we can do nothing about. You might be able to find someting in the audio menue of either your TV or Sound bar that will help some . . .
Jun 06, 2016 | Samsung Televison & Video
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Why if my antena is hooked to my dvd player is it not getting channels but my tv is if dvd player is turned off
The reason probably is because all broadcast TV is digital, and the em-55 tuner is set for analog channels. It cannot receive today's broadcasts "thru the air" because channel 2 for example is not broadcast, rather channel 2.1, 2.2, etc.
You can use the signal with a new TV, but when you turn ON the em-55, it inserts channel 3.
Most all TV here has what I call sidebands, and some have as many as 11, so the tv can be set for 3.1, or 3.2 or 3.3.
Even if you have a digital-to-analog device, the em-55 will not receive any .1, .2, .3, .4 and so on. I verified this recently reconnecting my old antenna to the converter then to several VCR's and DVD players.
Turn off the em-55, and the dot channels pass through the RF connectors..
Some DISH, cable direct TV receivers convert the signal to ch 3.
Sep 25, 2014 | Panasonic DMR-E55 DVD Recorder
Losing internet connectivity
Have you tried changing your wireless broadcast channel? It's possible the other devices are operating on a slightly different frequency as your toughbook, causing connectivity issues on that machine alone. What is your router's manufacturer? I can point you to guides to walk you through that, but they differ from company to company, so we would need that info to get a specific walkthrough. Additionally, are you running any USB 3,0 devices? If the cable's shielding is inadequate on a USB 3.0 bus, it can cause interference with WLANs by raising the noise floor and significantly reducing the range. Wrapping the cable in tin foil is an effective (although a bit southern-engineered) fix, if that is the case.
Dec 10, 2013 | Panasonic Toughbook CF-29 Notebook
I purchased a nexxtech VHF/UHF/FM Indoor Antenna to bring in digital signals to my HDTV. It helps with the one analog channel that I receive (CBC), but does not bring in the other channels that should be...
But the antenna u bought it is a digital antenna design though.Digital antenna design will help ur tv to getting broadcasting signals channels stronger and longer signals ranges though.
Sep 06, 2011 | Televison & Video
What does D03-1 mean
The TV has several inputs, Video 1, Video 2, HDMI, etc. One of the inputs is Digital. TV stations switched from broadcasting analog signals years ago. You may remember having to buy a digital antenna, or possibly if using cable or satellite service never knew it happened. You can press the input button on your remote until you see D03-1 on the screen and then do a channel search. You may pick up some extra channels that are being locally broadcasted for free in your city.
May 21, 2011 | Sanyo DP46849 46 in. HDTV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Playing vcr causes new digital tv to lose saved channels
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
Dec 01, 2008 | Vizio L37 Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
