Question about GE Dryers
Hi, My Simpson maxidry 456 dryer, heats up and appears to work, gets hot and cuts out. It is steaming the clothes but does not dry them. Would this be a fan problem, How can i fix it? Ta!
    Problem Solver:
  • 16 Answers
9 out of 10 times this is going to be a restriction in your vent line. Check where it goes outdoors and see if there is a steady flow of warm air. If not, take the vent off of the wall behind the dryer and either have a handyman snake it clear to the outside or take a leaf blower and blow it clear. A good way to test for a restriction before doing all of this is to run a cycle with the vent disconnected from the back of the dryer. The steam is a result of the hot wet air from the clothes having nowhere to go. Good luck =)
Posted on Jul 28, 2010
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
I'm looking for a Simpson maxidry 456 second hand door and hinge. Our dryer works perfectly.
Hi just read your posting.What country are you in?If it is AUSTRALIA then I can help you.Also if it is Australia then which part?Looking forward to your reply.
Sep 21, 2010 | Electrolux Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Simpson Maxidry 457 not heating
Check thermal cut outs/ Element Should read around 32 ohms on a multimeter if its ok...
Apr 09, 2010 | Dryers
My dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
Nov 08, 2009 | Dryers
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
276 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
