Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Don't have any compression when pulling the starter rope
  • 23 Answers
I've a 1435 and it has no reed-valve- it's piston-ported inlet, like yours.<br />If there's a spark-plug installed, and the crank is turning (pop the top cover and look) then you've a big problem, likely requiring replacement of piston
Posted on Aug 18, 2010
    Problem Solver:
  • 5 Answers
One of the reeds are not closing
Posted on Jul 28, 2010
How do I replace a starter rope on a troy built 4 cycle weed eater model no. tb685ec
Remove 4 screws that hold starter to housing, remove handle by cutting rope, notice how rope is wound and mark arrow on spool for direction, from drawing looks like there is a compression ring holding the spool in place, let tension of spring by allowing spool to unwind, Remove this ring very carefully to prevent damage. Remove spool carefully and let spring stay in starter housing. Rewind rope install in starter housing install compression ring wind cord in spool three turns pull through rope eyelet and install handle.
Apr 12, 2018 | Troy Garden
I have a 2005 brute force 750 and the starter is messing up or the flywheel is missing teeth. Why is the pull rope so hard to pull? U might get it halfway out and it almost will jerk the rope out of your...
starter motor pinions come in different pitches ( number of teeth) to suit a variety of applications
ring gears on fly wheels burr or wear in set points so remove the starter and check for burrs on the teeth on the ring gear from your description it indicates that the ignition timing is too far advanced and the firing before correct time will pull the cord out of your hand
so from you statement of the starter motor and the rope pulling problem I would bee looking at an ignition timing problem way too far advanced ( 8-10 degrees max)
Nov 14, 2017 | Cars & Trucks
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Hard to pull starter rope with spark plug in
You have to overcome the 100-135 psi of compression by pulling the rope. Some manufacturers now incorporate a 'compression release' to allow a rapid spin of the engine with a moderate pull. It automatically resets when it fires so you may have to push the compression release more than once to get them started.
Yours does not have that option which is why they suggest sitting the saw on the ground and inserting your toe into the handle while holding the front of the saw down with one hand. That allows you to ge a bit agressive with the pull rope with the other.
Apr 16, 2015 | Garden
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Gx160 pull cord rope broken
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like.
2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley.
3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both.
4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone.
5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part.
6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns.
7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing.
8. Let the pulley turn slowly so it retracts the rope.
9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle.
10. Reinstall the starter and you will be back in business.
Mar 06, 2012 | Honda Garden
Troy-bilt pull rope torx screw: Is there a trick to remove the torx screw in the center of the starter spring housing?
There is no trick, you would just use a torx screw driver. If your spring isn't broken don't do this. If your rope is broken you can fix easily. Replace old rope with new rope of equal size, place rope into spring wheel and turn counter clock wise holding the spring wheel. place other end of rope thru hole in shroud, remember to hold tight you have a lot of tension there. Pull rope thru enough to tie a knot, replace your pull handle , untie the knot and you should be fine. GOOD LUCK.
Aug 12, 2011 | Troy Garden
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
Starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Sep 17, 2009 | Bosch Garden
Chainsaw won't start. Can't pull starting cord out
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
54 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
