Question about Cameras
Memory card is protected how do i switch on memory card
  • omom12 Nov 24, 2008
    When i opened my Konica Minolta DiMAGE G400 Digital Camera
    it shows: Card protected
  • Anonymous Mar 11, 2009
    i have formatted a 64MB SD card WITH the camera and after the battery sucking VUTURE of a camera died, i later tried to take a picture and it says: "CARD PROTECTED"
    i even formatted a 64 MB SD card on a MAC (osx) & PC (xp) and the camera STILL says "CARD PROTECTED".  regardless of FAT, FAT16, FAT32.
    WTF!!?!  the SD card is not LOCKED so there shouldn't be a problem!  a capacity of 47 pictures registers in the top right corner, but the damn thing says "CARD PROTECTED"  when i click to take a picture.  don't they test these things?  or is this just a rarity?  every OTHER camera i have EVER used NEVER had this problem... EVER!  sad, pathetic, ridiculous.  i think i actually hate this camera.
    it does have a nice screen tho...gotta admit.
Fixed by kodak agent
Many thanks just the same
Ron......
Posted on Apr 24, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Memory card is protected {reset switch on memory Card} ? Go To review
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2014 | Kodak EasyShare M530 Digital Camera
I have a Kodak Z990 easy share camera and memory card is protected came up and said reset switch on memory card. How do I reset memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 06, 2012 | Kodak Easyshare Max Z990 12mp 30x...
Want to copy some files to a memory card from a laptop but it says that the memory card is write-protected. how do i remove the write-protection to copy the files.
Some memory cards are having a write protection switch integrated on the side or on the back of the memory card for preventing the content from being erased or overwritten by accident, just like floppy disks. Both SD Memory Card and xD-Picture Card have their write protection switch on the side of the memory card in contrast to the Memory Stick PRO and some Memory Stick Duo that have their switch on the back of the card.
The SmartMedia Card is also supporting write protection but not with a switch. For protecting the SmartMedia Card's content you need to put a sticker on the card's write protection pad. It is the circle that can be found in the middle of the card, when facing the front of the card.
Oct 24, 2010 | Computers & Internet
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Memory card is protected (reset switch on memory
make sure that the slider switch on the actuall memory card itself is not in the locked position
Jan 19, 2010 | Cameras
Says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
Oct 16, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
269 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
