Question about Gateway FPD 1940 (Black)
Powerlight come on when pluged in but monitor does not turn on
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and ALL other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Jul 28, 2010
Samsung syncmaster 244T. Powerlight blinks and no picture for about 5-7 minutes then steady light and monitor works fine.. Any suggestion?
monitor is power saving mode
when taking a monitor out of this mode is move the mouse or press keys on the keyboard You can buy a used from eBay for $100 or I would buy a new one for about the same price 24 inch monitors are around $100
May 14, 2018 | Samsung Computers & Internet
Replaced power supply still no powerlight tv inverter light comes on for 2sec when pluged in
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 09, 2016 | Televison & Video
My blue powerlight isnt working on my olevia tv it is 3years ol what could it be
If the tv is infact turning on eventhough the power light isnt, its the bulb for the powerlight itself
Nov 20, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
The TV shut off automatically but the powerlight is blinking
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 18, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a samsung syncmaster 930b that the powerlight flashes all the time and no picture no mater what CPU it is pluged into and can't be shutoff by power switch?
Check your Electric connection because these is not your moniter problem. There are problems of loose connectivity or open ground connection check it and your problem will be solved....
Regards :
ANDY
May 23, 2010 | Computers & Internet
I have completely black screen, and the powerlight stays blinking, can't shut it off
First place to check will be the power supply section, look for caps with bulging top, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I have dual screens and one of them has stopped working - powerlight is on but no picture
What are the types of your monitors?
(if it's Benq, then search for questions regarding your monitor - there are a lot of them here)
Nov 29, 2009 | BenQ FP71G 17" LCD Monitor
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Computers & Internet Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
