Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
Power wheel F150 only works in reverse. (nothing happens in high or low gear). The problem started after he sprayed the truck with a hose. Is it fixable?
My son had the same problem. At first I was angry because we just bought this toy, but then I realized he didn't have it in gear all the way. I had him put it in reverse and drive it back a little. Then I told him to put it in drive, and (making sure it was properly in gear), told him to go and it did. I think it just takes the kids a little while to get used to it and make sure it's properly in gear. Good luck!
Posted on Jan 12, 2011
  • hf2272
    hf2272 Apr 17, 2012
    no. mine is doing the same thing. even when I put it in gear...nothing. looking for an answer myself.
Why will my 2004 F150 transmission will not engage?
check tranny fluid. does it shift when its warmed up? tranny seals may be going bad
Aug 16, 2014 | 2004 Ford F150
My transmission in my 97 ford f150 wont move unless i put it in 4 low and now wont switch out of 4 low
Its Possible the chain in transfer case is stretched I had the same problem a used case was 250 at my local salvage yard
Nov 23, 2012 | Cars & Trucks
1999 GMC suburban and just out of the blue the transmission started to make a grinding noise mind you this is a 4wd unit it still will go but acts like it stuck in low gear and no reverse I tried different...
The sun-shell in the transmission has cracked if you do not have reverse, and are in a low gear range with no overdrive. As for the grinding, that is the remnants of the sun-shell.
Mar 24, 2011 | 1999 GMC Suburban
My question is about my 1992 subaru SVX automatic transmission. The Reverse, 1st,2nd and 3rd works, but nothing happens in D. We were a little low due to leaking hoses but no other signs of failure. Any...
try driving and shifting each gear manually, by hand until u reach "D". Also try some "trans X" sold at autozone& Advanced auto parts. try to run RPMs as high as possible before shifting.
Feb 20, 2010 | 1992 Subaru SVX
F150 SUPERCREW 4X4 5.4L Got stuck in the snow and
sounds like transmission damaged. if forward gears are operational, suspect transmission failure. If nothing working ( either in 2 or 4 wheel drive) suspect transmission or transfer case.
Dec 25, 2009 | 2004 Ford F150
I bought a 2000 f150 4x4, 5 speed. the truck
You can try several things. You can stop the vehicle as if you are going into low range and shift the high range 2h, 4h, etc.. Ford advertises the Electric button type as "shift on the fly" but does not say the gears are synchronized to do that with manual engagement.
Change the lube this time to see if the lube is Milky. There have been floods, otherwise the case is sealed whether you park it or drive it. You still could have rust on the shift linkage. You need to move the linkage as you spray it. Then the offbeat chance something was bent from offroading. A Salvage Yard is a wonderful place to learn how a car is built. You may see their part looks different than yours.
Nov 15, 2009 | 2000 Ford F150 Flareside SuperCab
Little Tikes Hummer
Its the battery, you can purchase new one on amazon. here: Amazon com little tikes hummer battery. I hope this was helpful. cheers
Mar 06, 2009 | National Little Tikes Hummer Yellow
Switch turned to 4-wheel high or low and nothing happens, truck is F 150 2005 model
I have A 04 F150 FX4 and I had A problem with mine while under warranty and it turned out to be the Shifting module. Thought this might give you something to check.
Dec 09, 2008 | 2004 Ford F150
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
538 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
